Old 05-13-2016, 01:42 AM   #1
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Guide: 2016 Camaro SS & LT Jack Points & Jack Stand Locations
The 6th Gen has proven to have some weak points you want to avoid jacking the car up from. I learned the hard way even with a wide plate jack on how the 4 point jack points should not be used for single corner lifting.
Check out how I am now successfully lifting my car with jacks and jack stands without any worry of breaking things.
Save 10% off on all products offered at ZL1Addons with coupon code lethal10. http://www.zl1addons.com
Also...
Here are the jacks, the stands, ramps, etc. I use in my garage. They all have a purpose and are useful in there own ways.
Sledgehammer70 is offline   Reply With Quote
Old 05-13-2016, 08:57 AM   #2
Tr6
The Dogfather
Drives: #1 off the line for a customer. '16
Massive plus 1 for the guide!
2SS, Garnet Red with Adrenalin red, NPP, MRC M6 coupe
#33 off the line #1 order for Customer.
Build thread HERE!
Story of my delivery HERE!
Tr6 is offline   Reply With Quote
Old 05-13-2016, 03:43 PM   #3
leadfoot93
Camaro Fan
leadfoot93's Avatar
Drives: 2016 Camaro 1SS Garnet Red
Lol told you this would be a good video to make! Great job as always
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15
3800 Status: 10/13/15 VIN #116519
4200 Status: 12/19/15
Delivered : 12/28/15
leadfoot93 is offline   Reply With Quote
Old 05-30-2016, 04:22 PM   #4
Jeanius
Jeanius's Avatar
Drives: Blk/Blk 2018 Sierra SLT
Just seen this, Thanks Sledge!!
SOLD: 2SS LS3 M6 - MGW - Dynatech LT's HF Cats - Magnaflow Street CB - ADM Race CAI - Pedders Xa Coilovers - Pfadt Sways
TRADED: 2016 2SS M6
Jeanius is offline   Reply With Quote
Old 05-31-2016, 04:26 AM   #5
Sledgehammer70
Lethal Camaro
No problem
Old 06-13-2016, 10:19 AM   #6
Blue's SS
Blue's SS's Avatar
Drives: 2017 Camaro 1SS, for go, not show.
Very interesting! So, if you use a 4-point/arm hydraulic lift you would need 4 of these pinch-weld protectors to lift the car or is it only for floor jacks?
Camaro/Firebird fan since 1977!
Previous rides: 1965 Pontiac GTO, 1977 Trans Am Special Ed. "Bandit", 1996 Camaro 3.8, 2002 Camaro Z28, 2014 Camaro 2SS/RS M6 Spring Special Edition
Current ride: "SOUTHERNCROSS" - 2017 Camaro 1SS Silver Ice Metallic/Jet Black w/BO4 56V RZ9 NPP SFE SH1 VW9 W2D
"And no BS! It's (the 1SS) everything you need and nothing you don't." -Craig Cole on the 1SS vs 2SS
"Reach above your dreams of pleasure, giving life to those who died. Look beyond your own horizons, sail the ship of signs." -RJD 'The Sign of the Southern Cross'
Blue's SS is offline   Reply With Quote
Old 06-16-2016, 06:58 PM   #7
Sledgehammer70
Lethal Camaro
Only for floor jacks, you should not need these for a 4 point lift.
Old 06-16-2016, 09:10 PM   #8
Blue's SS
Blue's SS's Avatar
Thanks for the information. Good to know, I was about to spend $160...phew!
Old 06-17-2016, 06:42 AM   #9
Com69
Drives: 2016 Camaro 2SS 6M Nightfall Gray
It really depends on the size of the pads on the lift. We have 3 lifts at the shop and the pads are a too wide for the cut-outs. If we didn't use something, they would squish my car! We made our own protectors out of some super-strut we had laying around.
Not all lifts have the same pads, just check, then double check, that when positioned, they aren't going to hit the rockers before getting to the recessed pinch welds.
Com69 is offline   Reply With Quote
Old 06-29-2016, 04:49 PM   #10
Bad Rap
Bad Rap's Avatar
Drives: 2016 2SS Vert. 2012 Ford Raptor
Sorry to say, you can only use the front pinch weld jacking point on the verts!
The one back little for your jack stand has the cross brace bolted to it. Also you can't get to the center jacking point in the rear because of the rear cross braces! At least we get to go topless!
Silver 2SS Vert, A8, NPP, MRC, Black Wheels, Black Rally Strips.
Bad Rap is offline   Reply With Quote
Old 09-23-2016, 12:16 PM   #11
getonit
Drives: 2016 2SS
Did anyone figure out if the front center jack point can be used without removing the plate that covers it? I would rather not use the pinch welds if possible.
Thanks for the great video! I feel confident if the pinch welds are the only option in the front,
getonit is offline   Reply With Quote
Old 10-31-2016, 12:48 AM   #12
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
Nicely done guide, sir.
Seems way to stressful to get the car in the air for basic stuff.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 11-01-2016, 09:05 AM   #13
vaspen
vaspen's Avatar
Drives: 2017 l4 blue 6speed
so a 4 post lift do I have to lift the smaller feet up onto the pinch points ? not that I don't know how to use a hoist I just want to make sure I don't crunch anything
and I shouldn't need 4 of those little pinch point things correct?
side note
the hoist is occupied by a 78 280z in the resto works
vaspen is offline   Reply With Quote
Old 11-04-2016, 03:42 PM   #14
CAM-FIFTY
CAM-FIFTY's Avatar
Drives: 2016 Red Hot 2SS
Hey Sledge,
quick question - how are you putting the magpad on the rear pinch weld? I find the black plastic strip there interfering with the magpad, if I force the magpad then it is not sitting straight and am afraid will bend the pinch weld.
Anyone else noticed it? Problem only with the rear, front one is ok.
2017 Black Z06 2LZ M7
2016 Red Hot 2SS A8 - Sold
My Camaro journey here and here.
CAM-FIFTY is offline   Reply With Quote
