Old 06-25-2013, 05:12 PM   #15
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
Originally Posted by MrGs SS View Post
You have to be kidding...
Lol
or keep it in 1st gear and never shift it unless necessary lol.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 06-25-2013, 05:33 PM   #16
supercharged zl1
supercharged zl1's Avatar
Drives: '13 camaro zl1 '08 daytona charger
supercharged zl1 is offline   Reply With Quote
Old 06-25-2013, 05:34 PM   #17
Denis
Denis's Avatar
Drives: 2010 SS
Originally Posted by litle88 View Post
Lol
Why am I only getting 2mpg?!?
Denis is offline   Reply With Quote
Old 06-25-2013, 05:34 PM   #18
midnighter
Drives: nothing
really?
midnighter is offline   Reply With Quote
Old 06-25-2013, 05:55 PM   #19
mikeyg36
Drives: 2015 Z/28 #533
Originally Posted by Mchlgrrsn View Post
If its manual ... Just push the clutch down use the handbrake and keep your foot on the gas, I think that will work.
Hey Garrison I think this guy can use a long throw shifter
mikeyg36 is offline   Reply With Quote
Old 06-25-2013, 05:57 PM   #20
skar
skar's Avatar
Drives: 2010 2SSRS headers/CAI/tune/corsa,
I love mine not to loud at idle but your ears will bleed at WOT.
Now I which cold start was not that loud or I should say the neighbors .
5:30 AM
Stainless works headers/cats Roto fab CAI /
Corsa install and tune Livernois
TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
JL Audio XD400/4 amp
Pfadt trailing arms & tie rods sway bars.
pedders street 1 package. ,Hurst short throw shifter
With bronze bushings .
skar is offline   Reply With Quote
Old 06-25-2013, 06:01 PM   #21
Mchlgrrsn
Stroked and blown
Mchlgrrsn's Avatar
Drives: 2010 LS3 2SS
I see the op is an automatic. That's even better because he won't have to use the handbrake. Slip it into neutral and stay on the gas. FTMFW
LME 416 LS3 shortblock/Callies Compstar 4340 4"crank/Callies 6.125 H beams rods/Wiesco 4.07 forged pistons/Cam Motion custom LS1/LME ported heads /maggie TVS2300/I West 8rib 10%OD /3.2 pulley/OD cog drive/JRE tensioner/ID850 /ADM dual fuel/Kooks LT 1 7/8/magna flow2.5 /cat delete/Roto Fab CAI /MGW short throw /SPEC super twin clutch/G Force built trans,carbon syncro rear shaft upgrade /DSS 9"single CF DS /Strange 3.70/31 spline trutrac/MT DR's/earls oil cooler /tuned KHC
Mchlgrrsn is offline   Reply With Quote
Old 06-25-2013, 07:16 PM   #22
thahemp
Geek
thahemp's Avatar
Drives: 2012 Black LS3
OP. Cutouts.
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1
x = ~x
thahemp is offline   Reply With Quote
Old 06-25-2013, 07:17 PM   #23
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Whistle tips FTW. You'll hear it ALL the time.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 06-25-2013, 07:28 PM   #24
thahemp
Geek
thahemp's Avatar
It goes "Woop Wooooop!" You know what i'm sayin?
x = ~x
Old 06-26-2013, 10:55 AM   #25
thepirate
thepirate's Avatar
Drives: 2013 2SS
You have a 2013. Do you have the dual exhaust mode? If so, those annoying little flaps control how loud your exhaust is at times.
It takes 5 mins to do the fuse pull to always keep them open.
thepirate is offline   Reply With Quote
Old 06-26-2013, 02:59 PM   #26
Jose
Jose's Avatar
Drives: 2010 Camaro 2SS/RS White S/C
Ohhhhhhhhh so that's what it is, when I put the car in the "D" it goes forward.......
"It does not matter if you win or loose, what matters is if I win" Carl Fogarty
Jose is offline   Reply With Quote
Old 03-03-2024, 08:42 AM   #27
Patfan74
Drives: 2021 Camero ZL1
I have a 21 ZL1 manual.
Mods
AR Headers
RotoFab
Corsa Exhaust
Lower pulley
When I start the car, it’s loud, going thru the gears, sounds great, but once I get into 4th gear, the sound goes silent, is this normal?
Patfan74 is offline   Reply With Quote
Old 03-03-2024, 10:06 AM   #28
anhtuvp
Drives: Man
Send a message via ICQ to anhtuvp Send a message via AIM to anhtuvp Send a message via Yahoo to anhtuvp Send a message via Skype™ to anhtuvp
Yeah, it's a common issue with mods like yours. You can try installing an exhaust cutout for more control over the sound, regardless of throttle input.
anhtuvp is offline   Reply With Quote
