08-05-2019, 10:00 PM | #1 |
Can't add a turbo or supercharger
A local shop here said I can't add a turbo or supercharger with the cam I currently have. It's a small cam:
GPI SS1 Cam Motion kit - 219/231 .638/.629 on 112 LSA Is there a reason why? Thanks.
Rotofab CAI, VMAX PTB, Borla S axle-back, Dynatech SuperMaxx 1 7/8" headers/HF cats, No weeds exhaust diverters, Apex air scoop & catch can, Rohana wheels, MPD1 Z-Force Hood, BTR Stage 3 cam, Vitesse Throttle Controller, etc...
08-05-2019, 10:22 PM | #2 |
Drives: 2010 inferno orange 2SS 6spd Join Date: Apr 2012
sounds like BS to me. I would go to another shop. I have the 525 asa crate engine and it has the asa cam. Im going to install supercharger on mine. even the the cam isn't a very good blower cam. I do know she will be faster then she is now.
roto fab cai
bbk full length headers High flow cats 411rwhp/411trq engine pulled/ oil pump fail 525 crate engine installed 391 gear installed 226/236 110 cam tuned by full throttle speed 443@6000rpm /420trq@4900rpm |
08-06-2019, 01:08 AM | #3 |
weSS1LEy
Drives: 2015 camaro 2ss/rs/1le Join Date: Sep 2015
People put blowers on stock cam all the time. Smaller than yours.
Rotofab, arh no cats, atak, elite cc, 94 octane tune, Mobil 1, phastek scoop, custom cam 230/243 .621 .604 114+4, related cam kit stuff. 470/435 rwhp/rwtq
08-06-2019, 03:07 AM | #4 | |
LSx FTW!!!
Drives: 2010 Camaro 2SS RS Join Date: Jan 2017
I run a TSP VVT 3.2 with a ProCharger D1X making 760 rwhp on E85.
You'll be fine with that cam.
2010 2SS RS A6 781rwhp on E85
Stage 2 ProCharger D1X Circle D 3400 Triple Disc Kooks Jet Hot Headers Kooks Full 3in exhaust Trick Flow GenX 255's Polished PAC .660's & Ti-retainers TSP VVT 3.2 cam kit w/DoD Delete Smith Bro's Trunnion kit AEM X-Series OBDII Widebands FIC ID1300x Injectors GM ZL1 High Output Fuel Pump DSX Tuning Flex Sensor DSX Auxiliary Fuel System Tim King Stage 4 Max Effort CTSV 6L90 DSS 1 piece aluminum driveshaft JRE 6L80E / 6L90E Dipstick NGK Iridium IX spark plugs #7 heat range Mighty Mouse Camaro 5 Wild w/-12an and Billet Black HP Tuners VCM Suite |
08-06-2019, 05:55 AM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
That's not really a small cam. The lift is higher than a btr stage 3 blower cam, less durationi think but still. A long time ago i was taught as long as you have about 10 degrees more duration on the exhaust side it will work pretty well on boost.... i'm on a stock cam with my whipple. I might stay away from that shop
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
08-06-2019, 06:03 AM | #6 |
LSx FTW!!!
My cam card
08-06-2019, 06:53 AM | #7 |
USA-1
Ya....find another shop.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
08-06-2019, 07:48 AM | #8 |
Drives: 2014 2SS/RS Join Date: Jan 2018
The reason why they are telling you that is because of your LSA. Smaller LSA is usually bad for boost set ups because it loses efficiency. You'll be fine running it but you'll see more power from a cam with larger LSA
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
08-06-2019, 08:34 AM | #9 |
I don't know that he would see more power, just a broader more linear curve. I'm no pro, just what I understood is the narrow LSA is for more power at peak but a narrower power band usually for NA. Superchargers don't need that but I don't think it would hurt, just not necessary.
08-06-2019, 09:00 AM | #10 |
Drives: 2010 SS L99 Join Date: Sep 2018
Even my SS4 can work well with a centri. NA cams tend to do well with centri blowers, their power curves are very similar, but for a PD blower or turbo, you'll need a dedicated blower cam/ custom grind cam for a turbo setup with that wider LSA. A shop should have told you this.
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
08-06-2019, 09:19 AM | #11 |
That cam only has 1 degree overlap. It would be better suited for a positive displacement/roots style blower. It wouldn't be ideal for a turbo car but would work great for a Whipple/Maggie or LSA style set up. I'm sure it would be alright on a centri but it will cost power on a turbo car for sure. Depending on what your ultimate power goal is it should work fine. If you need a supercharger hit us up. Can't help you with the install out in Hawaii though.
08-06-2019, 09:34 AM | #12 |
<-----Stock Cam with my Maggie
08-06-2019, 01:57 PM | #13 |
Thanks guys for all your input! I also emailed GPI where I bought my cam and they said, "John, we would likely make the same call here in the shop. Our SS1 is designed for Naturally Aspirated use - you could benefit much more with either a turbo specific camshaft or supercharger designed camshaft, both of which we offer!"
Turbo Cams: https://gwatneyperformance.com/produ...urbo-camshaft/ Blower Cams: https://gwatneyperformance.com/produ...ower-camshaft/ But from what I got from you guys, a supercharger would be ok with my setup.
08-06-2019, 02:13 PM | #14 |
You would be fine with a PD supercharger for sure. Just because it isn't the best camshaft doesn't mean it won't work and still give you a large power gain.
