08-28-2018, 08:42 AM | #1 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
Larger Capacity Oil Filter
Curious if anyone is making a larger capacity / taller filter for the 6.2L engines?
Used a PF64 for my 500 mile filter, getting ready to do the 1500 mile change. On my 1988 Monte Carlo SS I run the giant Wix 51794 filter (8" tall) - holds a extra quart of oil in the system I see Delco makes a PF63E (extra capacity) but not a PF64E, maybe there is an aftermarket source? |
08-28-2018, 08:45 AM | #2 |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
Is there any evidence you need even more oil capacity? What are you trying to accomplish here?
08-28-2018, 08:51 AM | #3 |
Its usually a easier way to gain oil capacity, filter area, etc... with no cost
08-28-2018, 09:04 AM | #4 |
Hot Dog
Of course it is, that wasn't my question, nor am I disputing any of that.
My question is; why do you think you need more capacity or filter area? Are you having filter particulate loading issues or oil pickup starvation issues? Have you looked under the car to see that adding a longer filter may not be physically viable?
08-28-2018, 11:42 AM | #5 |
These cars hold 8 quarts, not a lot of reason to add any more. Oil changes are expensive enough.
08-28-2018, 05:52 PM | #6 |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
08-28-2018, 05:54 PM | #7 |
Who Needs to KNOW?
I have always run bigger filters.. added filter media, lower pressure drop, practically free. At factory it may not make sense, but to me, if I can get something for minimal cost with very tangible benefits.. win win. Perhaps at next oil change I will check clearances around filter, etc.
ing for grip.
08-28-2018, 06:19 PM | #8 |
Hot Dog
You're still wrong. We're talking about the gen6 Camaro's with the LT1.
08-28-2018, 06:20 PM | #9 |
Thank you Al Oppenheiser!
08-28-2018, 06:40 PM | #10 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
08-29-2018, 08:16 AM | #11 | |
Drives: 2017 Camaro Join Date: Mar 2018
The factory installed a specific size for a reason. Adding one without knowing all the facts is probably doing more harm than good. |
08-30-2018, 09:34 AM | #12 |
This Is Bumblebee
Go to the wix website and find the correct filter. It'll show the thread size, valve PSI, etc. Then you can search and match the thread size. There is a wix filter that is close to the same width but longer with the same threads. Will it work? Probably but I personally wouldn't chance it but you could try.
08-30-2018, 10:16 AM | #13 | |
Who Needs to KNOW?
WHAT? Lower pressure drop across the MORE filter media.. no one said anything about bypass valve presets.. read a little ? Factory also installed specific size airbox and blower, etc.. yeah, why change those. Some people.
ing for grip.
08-30-2018, 11:22 AM | #14 |
I said something about bypass valve. Look up... see? Location of valve, the ADBV, the actual increase in media (larger filters some of the time don't have more media), pressure fluctuation during hard driving, cold start pressure build up, all these things must be figured in when picking an oil filter. Instead of your knee jerk " bigger is better" reaction without knowing if it's actually better. The only person to do all that research was GM and they figured which filter would protect better.
Thread Tools | |
