01-16-2021, 11:51 AM | #1 |
Drives: 2018 Zl1 A10 Join Date: Jun 2020
Magnuson 2650 Boost
I have a question about pulley boost and what would be the best option.
I have a ‘18 ZL1 with a 2650 with a 90mm and 9.1 lower pulley. I’m at 3-4K ft and it does have FED Ported heads. I’m trying to get to the 15-16# range and I don’t think this will get me there, with the variables. I was wondering if anyone has ran a 80/75mm upper with the 9.1 lower. What was your boost at? I figure I’m losing 4-5# with the elevation and heads. If anyone has setups similar and can help I would appreciate it. |
01-17-2021, 07:42 AM | #2 |
I would consider a 80mm Griptec and that should get you there with the 9.1 lower and 80mm upper. When I was at Magnuson our rule of thumb was for every 5mm of pulley change up or down you'd typically see 1.5 to 2 psi of boost change depending on other mods that can affect boost. You might exceed that a sea level. What is your elevation? I know when we had guys in Denver they would see about 2 psi of boost lose so a 5mm pulley change would generally bring it back to where it would be a sea level. My old Camaro with a 80mm and stock lower was at 12-13 psi and the 9.1 will add a couple lbs of boost. I think you'll be stellar with the 80.
01-17-2021, 09:30 AM | #3 | |
I’ve read that those can reduce boost too. |
01-19-2021, 08:04 AM | #4 |
Yes, both can lower your boost. The 3000 feet will probably be a 1 to 1.5 boost loss and with the ported heads probably 2 lbs total. So 80 or 85 mm would bring that back to stock boost levels that Magnuson figures at sea level.
01-19-2021, 04:54 PM | #5 |
01-20-2021, 08:14 AM | #6 |
01-20-2021, 12:40 PM | #7 |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
If you go with the smaller pulley to offset your altitude will you have to compensate with extra fueling?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
01-20-2021, 02:22 PM | #8 |
Not likely. Higher elevation will have less oxygen to burn, so less fuel needed. Dropping a pulley size just helps bring the boost level back up closer to what you have seen in a “closer-to-sea level” setup. Still have to watch your fueling as always, of course...
01-27-2021, 08:49 AM | #9 | |
Ted.
www.jannettyracing.com
