View Poll Results: Who has experienced an oil pump failure? | |||
2016 or earlier | 20 | 13.79% | |
2017 | 53 | 36.55% | |
2018 | 67 | 46.21% | |
2019 | 2 | 1.38% | |
2020 | 2 | 1.38% | |
2021 | 1 | 0.69% | |
Voters: 145. You may not vote on this poll |
Thread Tools |
12-05-2020, 07:06 AM | #603 | |
Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
So, I got lucky, I still have my original engine.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
12-05-2020, 09:53 PM | #604 |
Who Needs to KNOW?
Similar situation, i was pulling into parking lot, heard the chime, saw the message on cluster and shut it down. Literally seconds.
ing for grip.
01-16-2021, 02:30 PM | #605 |
Junkie
It seems like there have been more failures on ZL1s but can impact the LT1 also? My date is 4/17. I just saw a ZL1 with the same build date have a failure. Curious how worried I should be...
"Letty" Murdered out 2013 Camaro 1LE. (Old car SIM 2010 2SS/RS)
01-16-2021, 04:54 PM | #606 |
Drives: 2018 Camaro ZL1 Join Date: Feb 2020
It doesn’t look like anyone’s posted a failure (in an LT4) since August. Could these oil pump failures be a low probability event after all, or is it that folks are keeping mum about it?
01-17-2021, 07:24 AM | #607 | |
So, I would bet there have been more failures, but we won't hear of them.
01-17-2021, 11:46 AM | #608 |
Drives: 2018 ZL-1 Join Date: Jan 2018
01-17-2021, 12:53 PM | #609 |
Previously CS10SS
Drives: 2017 ZL1 A10 Join Date: Jan 2017
I wish this was a proven fact.
'02 Trans AM - sold
'05 SRT4 - sold '05 STI - sold '96 300ZX - sold '10 2SS/RS M6 455rwhp - sold '13 ZL1 M6 720rwhp - sold '17 ZL1 A10 930rwhp - Katech Built |
01-17-2021, 01:23 PM | #610 |
Drives: '21 Wild Cherry ZL1 Join Date: Aug 2018
01-17-2021, 01:27 PM | #611 |
Can I assume this engine cuts off when OP falls below some fail safe level like 10#?
Lost an oil pump at Indy one year when the pump sucked-in a screw from the valley. Engine was toast in less than 60 sec.
'20 ZL1 1LE A10,
01-17-2021, 09:23 PM | #612 | |
I can only speak for myself. But, when the oil pump in my 2018 died, my oil pressure dropped to 0 and the DIC started alerting me to pull over and shut off the engine. But, it DID NOT shut off by itself. FYI...
01-21-2021, 08:53 AM | #613 |
Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Seems like the 2019s are clean without any issue. Is there an upgrade of the pump on that year?
'20 & '21 aren't mentioned, I suppose that the pump issue was fixed. So mainly the pump problem was just on the first years. What about the LT1 engine, does it have the same oil pump issues?
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
01-21-2021, 11:37 AM | #614 |
Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
Same with mine. I immediately revved the engine a little to gain oil pressure. My car did not go with 0 oil pressure for very long.
01-21-2021, 01:26 PM | #615 |
Drives: 2019 ZL1 Riverside Join Date: Apr 2020
More than seconds is too long
I wouldn't even consider buying a car with a failed oil pump that had been replaced. This thread is played out though, maybe just keep the poll part of it open. Same old questions rehashed 20x |
01-26-2021, 02:32 PM | #616 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Anyone received their preordered LT4 pump from Katech yet?
TSP website shows that they have them in stock. Hope mine will ship soon, so I can continue with my build.
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, JMS Voltage Booster, Lingenfelter high flow check valve, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can 791whp, 772ft-lbs SAE Just added 30% XDI Injectors, LPE big bore hpfp, Flex fuel. Elite tuning, results coming soon. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: Swisstyphoon1980 Last edited by swisstyphoon; 01-26-2021 at 02:51 PM. |
