10-21-2019, 04:13 PM | #15 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
Ss vs ss 1le
I used to think the 1le was slower but whatever it loses in drag it probably makes up for with better stock rubber.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
11-16-2019, 09:39 PM | #16 |
Drives: 19 Camaro SS 1LE, 03 Ford Lightning Join Date: Nov 2019
That's not too bad. It's a 3,730 lb car putting down low 400 WHP in a car with a few aero bits designed to create some downforce, and wide tires that produce noticeable drag at higher speeds. For a N/A Camaro designed for RR'ing that's pretty good. With the OEM brakes you're never going to get the most ideal wheel and tire setup for DR, but I'm sure you can definitely improve on the OEM setup for DR.
Get some skinnies up front (if the make ones that will fit over the brakes) some slicks or good DR's on the back, drop the front swaybar, and turn off the T/C and you should see a very noticeable improvement in your E.T. and trap everything else left alone. Dropping easy weight from the car like the jack and fix a flat thing should also help some. I quit DR'ing nice street cars though. If you wreck at the track your insurance is going to give you the middle finger. Ask me how I know. Also if your car is still new (meaning low mileage) it should get a little faster as it wears in more. Wait until you have 15-25K on it and then re-run it. Your times in the same conditions will likely improve a little bit. |
11-17-2019, 02:00 AM | #17 | |
Drives: like an old lady Join Date: Jun 2012
video of the pass i referenced. if you listen you can hear it bite and then watch the front end bobble as it almost dies. tires had 40 psi in them after a nuclear burnout. the car smelled like clutch the entire pass. edit: i try to shift on the tach, right at 6500. logging the car shows an actual rpm of 6350-6400. i was afraid to run it into the limiter as that slows it down.
11-21-2019, 06:32 PM | #18 |
Don’t use NLS and the car goes faster.
11-21-2019, 06:50 PM | #19 |
ive heard this before. yet to see proof. it would take some serious consistency to compare.
11-22-2019, 11:41 AM | #20 |
I hear this also, and I know it cuts power so may be there's something to that... but when I roll race other m6 cars I usually pull ahead harder with nls... I know someone logged that it was a little faster with nls, but that is very dependant on individual driver.
11-22-2019, 05:32 PM | #21 | |
12-24-2019, 10:02 PM | #22 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Dude i ran almost exact same time/trap speed stock. I did not NLS. DA was not bad at all. Track was maybe 500 feet above sea level
1.9 60' These 6 speeds are a bitch to deal with at track
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
