05-27-2019, 05:35 AM | #1 |
Drives: Camaro ss 19 Join Date: May 2019
What oil and were to purchase/Motor oil
Just curious were to find the correct motor oil? Didn't see any were I went yesterday.. first 500 miles and its consuming oil on breakin... Thanks in advance
What brands are there in 0w40? |
05-27-2019, 07:55 AM | #2 |
Sure, why not?
Drives: 2016 Camaro 2SS, Jeep JKU Rubicon Join Date: Mar 2015
I ordered from Walmart. Bought 3 5 Qt jugs to save a little and get free shipping.
"Which oil" can be debated endlessly. You won't go wrong following what is listed in the owner's manual for your engine and model of Camaro, whatever that is. I have a 2016 2SS and have not taken it to a track, and am not sure if I will. I am using Castrol EDGE 5W-30 Advanced Full Synthetic Motor Oil and the OEM filter. https://www.walmart.com/ip/Castrol-E...-5-QT/34039135
05-27-2019, 11:52 AM | #3 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
Check this thread on Camaro oils.
https://www.camaro6.com/forums/showthread.php?t=552667 |
05-27-2019, 12:57 PM | #4 |
Drives: 2019 Camaro 2SS A10 Join Date: Feb 2019
I just did my first, and went with Mobil 1 ESP 0w40. AC Delco PF64 oil filter. Bought on Amazon.
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
05-27-2019, 01:01 PM | #5 |
05-27-2019, 01:04 PM | #6 |
05-27-2019, 11:38 PM | #7 |
05-27-2019, 11:39 PM | #8 | |
05-27-2019, 11:43 PM | #9 |
05-29-2019, 07:54 PM | #10 | |
Drives: 2019 1SS 1LE Join Date: Mar 2016
19 1SS 1LE - Suntek PPF - Corsa Xtreme Axle Back
05-30-2019, 08:03 AM | #11 |
Sure, why not?
Correct. If you go to the walmart link I posted and mouse over the image, you will get a much larger image that makes the Dexos logo easily legible. The 1 is still in the green square.
By contrast, Dexos 2 has a 2 in the box and the box is blue not green, like here: https://www.amazon.com/ACDelco-88865.../dp/B008BZS7CE This might be helpful: https://www.chevronlubricants.com/en...ification.html
05-30-2019, 11:51 AM | #12 | |
05-30-2019, 07:54 PM | #13 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I'm running Pennzoil 5w-30 and ACDelco PF64.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
06-05-2019, 03:40 PM | #14 |
Drives: '17 Red Hot 2SS 6MT Join Date: Mar 2018
For those interested in Mobil 1 0W-40 ESP the best deal can be had here: https://www.speedwaymotors.com/
I bought two 6-quart boxes for $49.99 each with free shipping. Also just got my rebate check from Mobil which was $12 per 5 quarts. So, I got 12 quarts for $76 (plus some taxes). https://apfco.com/secured/R10130W/ |
