12-17-2018, 10:36 AM | #1 |
Drives: 2018 1SS 1LE Join Date: Feb 2012
npp exhaust dumping fuel?
My car has 3,000 miles on it and i have noticed that gradually i have been seeing more and blow build up on the outside 2 tips of the npp exhaust. When i wash it (typically once a week), I polish the tips so i am only talking about a week or so of driving, and the 2 inside ones i hardly have to touch, but the 2 outside ones are black. Wouldn't that indicate that the air is basically just blowing through the 2 outside tips? I know air goes where there is least resistance, would this indicate the valves on the inside are not opening at the same rate as the outside? I leave exhaust on track, if that helps. Just curious why only 2 out of 4 tips seems to be dirty.
12-17-2018, 10:38 AM | #2 |
Drives: 17 SS a8 Join Date: Feb 2010
When open most of the exhaust will come through the outside pipes since there is less restriction there.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
12-17-2018, 10:48 AM | #3 |
Drives: 2018 Camaro 2SS 1LE, 1985 MCSS Join Date: Dec 2014
Track mode is your answer. When in track mode the outside tips are being utilized at 80%. If you use any other modes you will see less buildup. If you pull the NPP Fuse you will see even more as the flap will be 100% open.
People who have tuned their car to E85 have little to no build up since its a cleaner non carbon burn. I hope this helps! I had the same question when I bought mine.
2018 Camaro 2SS 1LE, White, M6, MRC, NPP, ELSD
Past/Current: 2011 Camaro 2SS Convertible, M6, Silver Ice Metallic, Inferno Orange Interior and Stripes - SOLD 2007 Monte Carlo SS, LS4, Summit White, Silver Rally Stripes - SOLD 2006 Impala SS, LS4, Black on Black - SOLD 1985 Monte Carlo SS |
12-17-2018, 11:44 AM | #4 |
Drives: 19 SS 1LE Join Date: Nov 2018
Mine is the same. Leave it in track, outside tips get black, inside look clean.
this picture might help, you can see that if you have the NPP in track, the flaps will be open the majority of the time and it will be a LOT of work for the exhaust gasses to reach the other tips. |
12-17-2018, 12:28 PM | #5 | |
12-17-2018, 01:47 PM | #6 | |
I'm the cats pajamas baby
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
Also, where is the fuse for the NPP? Thanks in advance.
12-17-2018, 01:53 PM | #7 |
Drives: '20 ZL1 M6 Join Date: Apr 2017
The fuse is #51 in the fuse box under the hood, passenger side. I always have my exhaust in track mode. I did pull the fuse, but the difference was almost imperceptible so I put it back so I can change modes if my wife wants a bit less sound.
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
12-17-2018, 02:10 PM | #8 |
I found and did the exact same thing with fuse #51. So I went into the main menu and set track as the full time default for the exhaust and I run sport for everything else. Two years ago I also painted the inside of all four exhaust tips with black hi-temp paint and haven't looked back. No more cleaning the insides - just a quick wipe down of the outsides when washing - all done!
12-17-2018, 02:31 PM | #9 |
I didn't notice any diff between Track and the fuse pull.
12-17-2018, 02:45 PM | #10 | |
12-17-2018, 04:04 PM | #11 |
Drives: 2018 1SS 1LE Join Date: Apr 2018
Biggest difference is the NPP valves will still close in track mode while on the highway - 6th gear / low rpm / low throttle.
2018 1SS 1LE (sold) |
12-17-2018, 04:36 PM | #12 |
i tried pulling the fuse, and also noticed little to no difference (after i bought all the parts to make a remote control fuse switch)
12-18-2018, 08:58 AM | #13 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
That's also why there's no change in volume when pulling the fuse. The valves are open by default from the valve spring setup and then the actuator holds them closed. No fuse = no power to actuator = valves always stay open, so going without the fuse will be the same as track mode with the exception that the valves will also stay open at high speed/low throttle conditions. In that case, you might get a little more sound on the highway, but that's about it.
2017 SS 1LE.
12-18-2018, 10:55 AM | #14 | |
Mal
