Old 09-04-2018, 10:21 PM   #15
cooper1965
Coopers Camaro
cooper1965's Avatar
Drives: 18 Flex Fuel LTG
Originally Posted by Thandel View Post
May I ask why? I honestly never knew much of a difference in plugs prior to reading anything about them. It seems the projected tip centers the spark better in the chamber and burns cleaner.
Very basically, A projected tip has a long red hot piece of metal further in the chamber , heat range only deals with the ceramic surrounding the center electrode.
Flex Fuel tuned by me using HPT-:-
---My Build Thread---
-----My IG PAGe-----
Old 09-05-2018, 05:29 AM   #16
Thandel
ATS 2.0T
Drives: 2013 Cadillac ATS
Much appreciated. I also did some reading on the subject. For anyone else wondering.. non protected is for high compression or boost applications it essentially makes it harder for “hot spots” in the chamber, decreasing the chance of detonation. Go with the non projected for our cars!
Thandel is offline   Reply With Quote
Old 10-17-2018, 11:32 AM   #17
cooper1965
Coopers Camaro
cooper1965's Avatar
Bumping this up for a good deal, not sure how long it will last. I was going to order my pre-gapped NGK's through Adamtuned.com, when checking out I was informed of the massive NGK backorder. They offered an upgraded Brisk option for the same price ($45 pre gapped) The picture shows RR14YS's, those would have been fine, but to my pleasant surprise, I opened my package today to find the RR14S pre gapped! Pretty good deal IMO.
Old 10-18-2018, 07:20 AM   #18
Thandel
ATS 2.0T
I ordered the brisks got them last week will put them in once I put my downpipe in.
Old 10-18-2018, 09:36 AM   #19
Start The Machine
Start The Machine's Avatar
Drives: 2016 M6 2.0T
Is any benefit replacing the stock plugs straight across for these. Not going a step hotter or colder?
RS Package, HD Cooling Package, Brembo 6 Piston Front Brakes, SRP Racing Pedals, Soler Performance Throttle Controller, Dyno Tuned by Trifecta, Velossa Tech Ram Air, Mishimoto Intake, aFe Air Filter, Mishimoto Charge Pipes, ZZP 67mm Throttle Body, Trifecta T40 Stage 2 Turbo, JacFab Recirculation Valve, PTP Turbo Blanket, ZZP Catted Downpipe, Mishimoto Pro Cat-Back Quad Tip Exhaust, Mishimoto Catch Cans, Mishimoto Coolant Reservoir Tank, GM SEMA Grill, Ikon Motorsports Front Fascia Extension, Ikon Motorsports 1LE Spoiler, American Authority ZL1 Side Skirts, AMPP Quad Tip Rear Valance
Start The Machine is offline   Reply With Quote
Old 05-13-2019, 07:37 PM   #20
EWard
Drives: 2019 Camaro RBM M6 LTG 1LS
It's been awhile and I while was looking for first hand feed back on the different plugs that have been discussed, including plug gap.
Can you experienced guys shed some light on your experiences with the aftermarket plugs.
In the future I would like to run the racechip once the bugs have been worked out for warranty purposes.
Thanks,
EWard is offline   Reply With Quote
Old 05-14-2019, 09:21 AM   #21
zts1986
Drives: 2019 Chevrolet Camaro 1LT 2.0T
After increasing boost via other modifications, I was getting some blow-out of the plugs. Going one step colder and closing the gap solved that issue and the car runs great.
NGK 6510s gapped at 0.022." The stock plugs were gapped between 0.032" and 0.034."
zts1986 is offline   Reply With Quote
Old 05-14-2019, 11:11 AM   #22
Evil-Bee-NH
603 Camaros
Evil-Bee-NH's Avatar
Drives: 2017 NGM I4 1LT Coupe
So what other modifications increased boost to cause blowout?
Old 05-14-2019, 01:55 PM   #23
Start The Machine
I was wondering the same thing.... what did I miss.
Old 05-14-2019, 02:45 PM   #24
EWard
For the guys running the Brisk RR14S do you know what spark plug gap you are running.
Old 05-14-2019, 04:39 PM   #25
Thandel
ATS 2.0T
I’m running .28 runs good no misfire no codes.
Old 05-14-2019, 05:16 PM   #26
zts1986
RaceChip GTS. Not 100% certain that that was the cause but it was my best guess. When I replaced the plugs, the problem went away.
Old 05-14-2019, 06:13 PM   #27
Start The Machine
Is there any noticeable performance gains over the the stock plugs?
Old 05-14-2019, 09:16 PM   #28
Evil-Bee-NH
603 Camaros
If the RaceChip increased boost enough to cause spark blowout then I'd dump it quick. There's gotta be something else causing the issue atleast i would hope so for those that spent money on RaceChip.
