02-17-2024, 10:56 PM | #1 |
Drives: Supercharged 45th 2012 Camaro SS Join Date: May 2019
Tire Recommendations?
I'm making about 626whp and currently have Nitto NT555 G2's. They were good for stock performance, but now when I put the power down it's like im on ice. I can hook for shit in 1st or second, and I usually break loose in third. Anyone have a good recommendation for tires that will help me get the power to the ground?
Not worth doing any more fun power mods until I can starting using it. Thanks! Jake |
02-18-2024, 04:34 AM | #2 |
Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
+1
DSS FX Forged Pistons, Eagle ESP L19 Forged Rods, ARP Head and Main Studs, TSP PRC 260 CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Performance Racing Lifters, CHE Trunnions , Molly Pushrods, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP 1 7/8" Longtubes with 3" TSP Exhaust, ZL1 Fuel Pump, Mishimoto Radiator, Mishimoto Oil Cooler, Tru Cool 40k Tranny Cooler, 3600 Circle D Converter, Fluid Dynamics Balancer
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
02-18-2024, 06:43 AM | #3 |
Drives: 2013 zl1 vert Join Date: Dec 2018
I'm running the Nitto 555r2 on both of my set of rims. They grab really well. You can break any tire loose if you try. Or you can try the toyo r888 if you want to spend more money.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 850/ dsx aux kit/ 103mm throttle body/ RPM 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ brick mod/BMR toe and trailing arms/ 751hp 757 tq SAE @17.3lb on a loaded dyno.
