Old 01-14-2023, 09:17 AM   #1
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Convert Kooks Header to V-band Clamps?
Hello.
I was curious if anyone has converted their headers from the garbage ball and socket joints at the header collector to V-band style clamps?
I have Kooks headers and I keep getting an intermittent P105B code from an exhaust leak. I suspect it is the ball and socket connection. Kooks now uses a rounded band clamp that I don't think seals very well. I do use the high temp exhaust gasket sealant from Permatex but I keep getting the code.
Kooks used to use a clamp that was a flange on the header and a flange on the connector pipe that pulled the tow pieces together and you could really tighten up on it. The new style just sucks.
I am going to change out my header flange gaskets just in case but I doubt it will help.
Was thinking that changing over to a V-band could solve this. Only problem is finding an exhaust shop that knows what the hell they are doing.
Spaceme1117 is offline   Reply With Quote
Old 01-14-2023, 10:52 AM   #2
04DetroitLS
Drives: 2022 LT1
Originally Posted by Spaceme1117 View Post
Hello.
Im having a hell of a time finding someone to tig o2 bungs in my headers so I feel your pain :P
I knew tons of shops in Detroit, not many down here though
04DetroitLS is offline   Reply With Quote
Old 01-14-2023, 11:11 AM   #3
AZIROC
Drives: '86 IROC-Z '18 ZL1
If I wasn't in a rush to put the exhaust on, I'd prob went v clamps. But the regular clamps worked for me after I got them adjusted.
Old 01-17-2023, 06:36 AM   #4
Spaceme1117
So update. I figured I might as well try to tighten up my exhaust manifold to head bolts and see if maybe that would fix my issue. None of the bolts were loose but they did turn a bit as I tightened them to 20 lb-ft. And that seems to have fixed the problem.
So fingers crossed for now.
Old 01-17-2023, 08:59 AM   #5
easttxss
easttxss's Avatar
Drives: '16 2SS M6
That is where my leak and codes were originating from when I bought the car. Replaced the gaskets and have not had any more issues.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 01-17-2023, 09:59 AM   #6
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
I upgraded my ARH flanges to V bands, and wish i would have done this before i powder coated them. The seal is so much better, with no leaks.
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
Old 01-17-2023, 11:35 AM   #7
cheeze9878
cheeze9878's Avatar
Drives: 17 camaro ss
If you can, try taking them off and just taking the headers to the shop so they don't have to worry about emissions stuff
cheeze9878 is offline   Reply With Quote
Old 01-17-2023, 11:49 AM   #8
NW-99SS
Drives: 1999 Camaro SS M6 - SBE LS1
This might not apply to the OP, but after installing headers, it's advisable to at least re-torque your header bolts after 1 or 2 heat cycles.
Note, the temp at which you torque plays an important aspect in this as well. Torqueing warm or hot, is actually much higher torque than cold.
1999 Camaro SS 6M - SBE LS1
1963 Corvette GrandSport - ZZ502 4M
2017 Denali 1500 6.2
2017 Yukon Denali 6.2
NW-99SS is offline   Reply With Quote
Old 01-17-2023, 11:52 AM   #9
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
Good point. Same logic as don't torque your wheels when the car is hot. Best practice at the track is torque the wheels each morning before heading out for a session (when the car is cold).
YouTube
Old 01-17-2023, 04:03 PM   #10
NW-99SS
Lots don't realize this and then wonder why it's so hard to remove certain bolts/nuts that were torqued hot.
Old 01-18-2023, 09:11 AM   #11
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
the ball and socket flange works very well, when used properly. don't forget that you have to torque the clamp..... excessively tightening it will cause a leak.
have you tried replacing the oxygen sensor?
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 01-19-2023, 07:11 AM   #12
tbair64
tbair64's Avatar
Drives: 2022 Camaro LT1
where in Florida are you. Might be able to help you out if your close and they are off the car.
tbair64 is offline   Reply With Quote
Old 01-23-2023, 07:08 PM   #13
04DetroitLS
Drives: 2022 LT1
Space coast,
Headers are still off the car, found one place that does tig, but they close at 3pm and #fulltimejob
