Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 10-07-2009, 08:38 PM   #1
XTREMESS
XTREMESS's Avatar
Drives: 2011 CAMARO 2SS SYNERGY GREEN MET
hurst shifter/ dust cover boot
anybody else having a problem keeping the dust boot on the shifter after installing the hurst shifter.
the rubber on my drive shaft has popped it off twice, and now has ripped it off yesterday.
XTREMESS is offline   Reply With Quote
Old 10-07-2009, 09:05 PM   #2
04ssSilverado
04ssSilverado's Avatar
Drives: above `12 zl1 #780
yes; i'm right there with you. i have asked several people to find a proper replacement. no luck
04ssSilverado is offline   Reply With Quote
Old 10-07-2009, 10:58 PM   #3
subzero05
Drives: 2010 tbd
call and see if Hurst can be of assistance
subzero05 is offline   Reply With Quote
Old 10-08-2009, 07:34 AM   #4
mstrfdsstr
mstrfdsstr's Avatar
Drives: 2010 SS/RS CAMARO
checked mine yesterday it was fine you sure you put it back on right no offence.
IOM 2 SS/RS LS3 vin9862
mstrfdsstr is offline   Reply With Quote
Old 10-08-2009, 09:46 AM   #5
subzero05
Drives: 2010 tbd
i believe it is pretty tricky to keep it secure, but yes maybe it didn't get completely installed correct?
Old 10-08-2009, 11:18 AM   #6
XTREMESS
XTREMESS's Avatar
the first time i must of not had it on there right, cause i took it around the block and it popped off. but i made sure it was on there good and it was on for about a week and then
gone.
Old 10-08-2009, 12:09 PM   #7
TRooper
Resident Stormtrooper
TRooper's Avatar
Drives: Creations n' Chrome Red Mustang GT
The installation of the boot can be a bit tricky. Keep in mind the parts in question are factory parts and are not unique to the Hurst shifter. The pivot point of the Hurst and the factory shifter pick up the linkage arm in the same location, so I don't believe the Hurst shifter is the culprit. It is a tight squeeze in there, and the driveshaft and tight tunnel make it even more difficult to work in. This is one instance where having a small set of hands to help would be beneficial. Also, how is the vehicle being lifted? Is it on a drive on lift or set of ramps? Are you just jacking up the front or side of the car. The reason I ask is because if you put the car up on 4 jackstands and allow the rear suspension to get full droop, it should increase the driveshaft angle and give you more room to work with.
TRooper is offline   Reply With Quote
boot, dust cover, hurst, shifter
first Camaro Hurst shifter installed in 2010 Camaro 2SSRS@Gen5diy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 347 10-17-2009 12:10 PM
Hurst T-Handle on my hurst shifter 2SSRS@Gen5diy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 51 10-07-2009 02:40 PM
Dumb question (sorry in advance) Hurst Shifter 2Muchmark 5th Gen Camaro SS LS LT General Discussions 0 04-16-2009 04:52 PM
* The TRUTH about the HURST SHIFTER OPTION ANNOUNCMENT * CamaroScotty Camaro Price | Ordering | Tracking | Dealers Discussions 53 03-17-2009 11:32 PM
Thread Size on Hurst Shifter? r0cketdr Cosmetics and Lighting Modification Discussions 0 11-18-2008 01:29 PM
