Old 04-19-2017, 09:03 PM   #15
TJay74
Originally Posted by crazydmc View Post
thanks... that is true if I keep the same diameter as stock.... but what if I wanted (for whatever reason) a bigger diameter.... could I calibrate the car to the new diameter?
You will not be able to recalibrate thru the dealer at all, the only way to recalibrate for tire size changes is via a 3rd party tuning solution like HP Tuners, EFI Live, Hypertech and the such. Then you take a chance on warranty issues.
Old 04-25-2017, 08:35 AM   #16
Hawk397
Sparky
Drives: 2017 50th Coupe / 2017 ZL1
How much do the front stick out past the fender lip? What do you think about 275/35's up front, just a little bit norrower?
Thanks!
Mark
Originally Posted by MRRWheelsInc View Post
@whiterocket 10 and 11 are of the norm on these cars, here are the off set requirements all just depends on the brand but here is what we offer and use.
20x10 5x120 23et with a 285/30/20 tire
20x11 5x120 43et with a 305/30/20 tire
no mod requirements, no spacers, no cutting, nothing just straight bolt on.
even if your lowered your good to go.
Hawk397 is offline   Reply With Quote
Old 04-25-2017, 09:35 AM   #17
drivingagain
drivingagain's Avatar
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ!
I run 285/35/r20 with same specs as the 20x10 et 23 in the front. The tires are right at the edge of the fender of a 1SS. No rubbing at all. I also did the 305/35/r20 with 20x11 et 43 and no rubbing in the rear but did relocate the wiring just in case. I am running the new Continental tires as well. Tires will make a difference on the width.
drivingagain is offline   Reply With Quote
Old 04-25-2017, 10:31 AM   #18
GP86
GP86's Avatar
Drives: 2017 2SS
Is there an issue with tram lining on such large front tires? I daily drive, so I am having a hard time deciding on 285/305 or maybe just a bit smaller at 265/295. My major concern is wet performance of the stock tires. I have had some terrible hydroplaning/tram lining with the front tires during very heavy rain storms. Despite the projected excellent performance of Conti EC Sport, or Michelin PS4S, I don't want to go so wide that I continue to have drive-ability issues in the wet.
2017 HBM 2SS A8|F55|NPP|H01|IO6|RIK|WGL|56R
GP86 is offline   Reply With Quote
Old 04-25-2017, 11:02 AM   #19
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
It would take the right offset rim.. like for instance the shocks of the 1le zl1 are different vs providing room for those tires/rims to fit! most of the problem is not the fender for rubbing but upper area where shock mounts..
Old 04-27-2017, 08:07 AM   #20
gdgraph
gdgraph's Avatar
Yes 20x10 front & 20x11 rear fit, I have them on my car and so do many other SS owners. A 305/30 fits fine, but if you do a 305/35, the tire is a little taller and rubs on a tiny spot of the liner, as long as you do the harness relocate for the left rear you'll be fine.
gdgraph is offline   Reply With Quote
Old 12-17-2019, 05:54 PM   #21
mikey522
Drives: 2018 camaro ss1
will the stock run on flats fit?
even if your lowered your good to go.[/QUOTE]
mikey522 is offline   Reply With Quote
Old 02-19-2021, 09:57 AM   #22
BumbkebeeRallySport
Drives: 2010 Chevy Camaro RS transformer ed
Hey does anyone know if the 2018 ZL1 1LE rims will fit on a 2010 camaro RS?
BumbkebeeRallySport is offline   Reply With Quote
Old 02-23-2021, 12:29 PM   #23
Aaron07
Aaron07's Avatar
Drives: 2017 2SS F1FTY
Originally Posted by FlowForm_Wheels View Post
Yep, that definitely works if we're talking about 20x10 and 20x11 in the right offsets of course. Here's a set of 20x10 ET23 and 20x11 ET43's with the 285/305 tire combo so you can see how that fitment looks on a SS.
Those wheels look great, what models are they, and is this car lowered?
Aaron07 is offline   Reply With Quote
Old 02-23-2021, 12:58 PM   #24
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
thats my car lol those are flowform ff04 wheels and yes i was lowered on afe power springs with no magride but i have since then replaced them with yyz springs
Old 02-23-2021, 03:03 PM   #25
Aaron07
Aaron07's Avatar
Very nice! I’ve got Eibach pro kit on the way. Saw these wheels and they look tempting for my 50th Anny. Same color as yours.
Old 02-23-2021, 04:47 PM   #26
kropscamaro16
awww nice its a nice setup but i think they discontinued them
Old 02-24-2021, 10:50 AM   #27
c4racer
Drives: 2016 SS Convertible
I run 295 square and don't notice much tramlining at all. Might be tire dependent.
I am running Pilot SS
I also find the steering just a touch heavier and more feedback - which I prefer.
c4racer is offline   Reply With Quote
