04-17-2017, 07:58 PM | #1 |
Drives: 2016 2SS White w/blk whls, MRC, 6sp Join Date: Mar 2017
Will 10" and 11" wide wheels fit a 2SS?
Stock is 8.5" front with 245/40 tires and 9.5" rear with 275/35 tires. Chevy can't tell me if the 10" 285/30 front and 11" 305/30 will fit a SS. The 2016 catalog offers these wider wheels for the SS (called split spoke satin graphite).
The wider wheels fit the ZL1 and 1LE but I do not know if the fenders are flared out to fit them. Does anyone know if the wider wheels and tires fit a SS? |
04-17-2017, 08:01 PM | #2 |
Drives: 2017 Camaro 1LE Join Date: Mar 2017
Yes, tha 1LE come with 10 inch fronts and 11 inch rears just get the offset numbers and match it up. I love the look on mine with 285 fronts and 305 rears.
04-17-2017, 08:02 PM | #3 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Yes they will fit just fine, nothing was done to the car for them to fit as long as you are talking the OEM 20x10 and 20x11 front and rears with the OEM offsets.
04-17-2017, 10:01 PM | #4 |
Drives: 2017 Chevrolet SS 1LE Join Date: Oct 2016
Any 20x10/11 can work with the right offsets yes, only thing is proper tire sizes.
04-17-2017, 10:14 PM | #5 |
ummmm
Drives: 2016 2SS M6 Nightfall w/Blk Wheels Join Date: Jul 2016
one more question... are the alignment specs different on the 1LE and if so, is the 2ss adjustable (camber, castor) ?
04-17-2017, 10:48 PM | #6 | |
..and all cars have adjustable caster and camber, but requires an alignment machine. |
04-18-2017, 08:02 AM | #7 |
Where can I get the offset specs? I can try the local Chevy dealer but from my prior experience on the topic they won't have that amount of detail.
04-18-2017, 01:12 PM | #8 |
Drives: Camaro Join Date: Jan 2016
@whiterocket 10 and 11 are of the norm on these cars, here are the off set requirements all just depends on the brand but here is what we offer and use.
20x10 5x120 23et with a 285/30/20 tire 20x11 5x120 43et with a 305/30/20 tire no mod requirements, no spacers, no cutting, nothing just straight bolt on. even if your lowered your good to go. |
04-19-2017, 04:11 PM | #9 |
ummmm
is there a way to fix (calibrate) the speedo / odometer if I change rear tire diameter?
04-19-2017, 04:15 PM | #10 |
Drives: SS-6-SPD Join Date: Jan 2017
04-19-2017, 05:58 PM | #11 | |
Drives: Turbo 4, SC V8 and Twin Turbo V8 Join Date: Jan 2014
04-19-2017, 06:04 PM | #12 |
ummmm
04-19-2017, 06:11 PM | #13 |
04-19-2017, 07:07 PM | #14 |
Drives: 16 Red Hot 2SS Join Date: Oct 2016
305/35/20s are only about 3 mph slower on the speedo than actual speed
'16 Red Hot 2SS A8 sunroof
