Old 11-05-2015, 11:51 AM   #141
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by wally mayfield View Post
sweet.....
Let me know if you have any other questions.
Apex Motorsports is offline   Reply With Quote
Old 11-08-2015, 12:38 AM   #142
Bodywerks
Drives: 2015 2SS/RS/1LE
What about forward traction loss with lowering springs? Since the angle of the rear trailing arm becomes lower when the car is lowered won't that affect how the tire bites from, say, a drag race launch?
2015 SS/RS/1LE
HSA delete, VMAX throttle body, CAI inc. Intake, PRC255 heads, BTR 660 springs, BTR cryo-treated rockers, PAT G 232/240 .654/.626 110+2, johnson 2110's, Manton 502 pushrods, C5R, Melling high volume/high pressure, Powerbond 25% underdrive pulley, Proform covers, Kooks stepped headers, catless mids, Doug Thorley exhaust. 512rwhp, 446rwtq on a mustang dyno, tuned by Cunningham motorsports.
Bodywerks is offline   Reply With Quote
Old 11-08-2015, 07:04 AM   #143
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Lowering will affect launch bite, yes. But there's a little more to it than just the trailing arm's inclination. Also, the amount of rearward load transfer will drop . . . precisely because you lowered the CG.
Norm
Old 11-18-2015, 11:13 AM   #144
Apex Motorsports
Correct. If 1/4 mile numbers are your priority then lowering springs are not what you want. Coil overs are the best route because you can fine tune the dampening to optimize weight transfer.
Old 11-22-2015, 11:19 AM   #145
Silverado60
Silverado60's Avatar
Drives: 2010 camaro 2SS/RS M6
Originally Posted by Caseyls3 View Post
Apex will hook you up. They recommended a package for me and I am thrilled:
What size wheel spacers do you have?
Your car looks great!
Texas speed F-35 cam, rollmaster timing set, melling hp pump, ls2 chain damper, fluid damper 25% under drive, Che rocker bushings, tsp .660 lift valve springs, BBK CAI Amzoil filter with Phastek ww relocation and scoop, Gmpp axle back, Speed engineering 1 7/8" LT's no cats, Peak speed shop ported tb, NGK tr6, MSD wires, Amsoil Zrod wix, heritage grill, 1.25" BMR springs, MRR 228, Nitto Nt05,dyno tuned by complete street performance, elite eng catch can, clean side separator, Hurst shifter, Zl1 addon wickerbill
Silverado60 is offline   Reply With Quote
Old 11-22-2015, 12:32 PM   #146
Apex Motorsports
They are 23mm all around.
Old 11-23-2015, 04:28 AM   #147
derek1387
Drives: 2015 1LS Red V6
So, I am putting the 1LE suspension on my car over the winter. All of the aggressive alignment specs I am finding are saying to use 1" of drop with them.
What springs do you recommend to go with the 1LE Struts? The 1LE/SS springs are already installed, obviously. But figure would be easy to swap them out with the struts OFF of the car right now.
2015 1LS V6, if that helps
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 11-23-2015, 07:54 AM   #148
Norm Peterson
A 1" drop causes cambers to go a little further negative than their 'before lowering' settings, so it may be partly a case of slightly more negative settings being easier to achieve once your car is lowered.
Or it may be based on the assumption that most drivers who drive the corners aggressively enough, often enough, to clearly benefit from running cambers more negative than stock are likely to have installed "lowering springs".
It is entirely possible to be a hard enough driver through the turns to need a little extra negative camber without being lowered. Trust me on this.
Beyond asking what your future driving plans include (such as autocross, road course, drag, etc.), whether you want a stockish ride or something a bit firmer, or if it's mostly just for appearance, I think I'll leave the question of which springs to others . . .
Norm
Old 11-23-2015, 11:02 AM   #149
elmayimbe
elmayimbe's Avatar
Drives: 2013 Camaro 2lt RS
What are your tire sizes? because I want to do the same thing to my car and i have the stock tires. What brand of spacers and from where did you buy them?
Thanks
elmayimbe is offline   Reply With Quote
Old 11-23-2015, 11:36 AM   #150
Caseyls3
Drives: 2011 Camaro SS/RS Convertible
I responded to your PM but for others:
Wheels and tires are stock sizes
Spacers are H and R 23 mm on all 4
The rear is a bit aggressive - 20 mm would be perfect but would have required me to cut the studs which I wanted to avoid. Front at 23 mm is perfect. This is a "stop gap" as I try to decide what wheel package to go with
2011 Camaro SS/RS Vert - Jewel Red Tintcoat, 6M, 231/247 Comp Cam, Kooks headers, Borla ATAK, ATI under drive pulley, Richmond 4.10s, LS9 clutch, Hurst shifter, BMR Springs
Caseyls3 is offline   Reply With Quote
Old 11-23-2015, 12:32 PM   #151
elmayimbe
elmayimbe's Avatar
Thanks for the reply and the pm.
Old 11-23-2015, 06:31 PM   #152
Apex Motorsports
I see what you did there.
Old 11-24-2015, 03:06 PM   #153
Caseyls3
. Glad you caught that
Old 11-28-2015, 10:29 PM   #154
QmaroSS
No regrets the red one!
QmaroSS's Avatar
Drives: 2012 Victory Red 2SS
Originally Posted by elmayimbe View Post
What type of springs and size did you get on your car? Looks good.
We did 1.25" springs up from and 1" springs in the rear. The convertibles have more weight in the rear and if we had done the 1.25" all around the rear would have sat lower than the front. To achieve a similar look on a coupe all you need is 1.25" all around.
What brand of springs were used? I assume BMR?
StainlessWorks LT (JetHot Coating) + HFC + Performance Connect, 3" SW Retro Cat-back, Roto-Fab CF CAI, Bo White PO TB, R1Concepts Drilled-Slotted Rotors, Hawk Ceramic Pads, AirLift Performance 3H suspension, MPD1 Rear Spoiler, Heritage Grill w/ Red SS Sparks Emblem, SLP Front Splitter, NightOwl V2 Halo Kit, Roto-Fab Red Engine cover w/ CF Plenum & Fuse Box Cover
QmaroSS is offline   Reply With Quote
apex lowering springs, apex motorsports, best lowering springs, camaro lowering springs
