02-11-2011, 10:19 AM | #1 |
Drives: 2010 2ss iom Join Date: Aug 2009
Need help with trunk rattle!!!
A W6 12 sounds great untill 2 days later the front of the trunk started rattling even at low volumes. Looks like between the weatherstripping and the back glass. Anyone fix this yet and how?
02-11-2011, 11:15 AM | #2 |
Drives: 10 2SS/RS Black, 99 Daktota Join Date: Apr 2010
I had a similar issue last year and the consensus here was that i needed to properly dyna-mat the trunk and under side of the trunk lid. I don't have my car right now, and did not get a chance to do it before it went into storage for the winter so i cant say for sure if it will work for me, but it did for others. Do a search on trunk rattle and i think you will find a few threads about it. One person suggested putting some of that weatherstripping foam with the adhesive on one side on the back lip of the trunk which fixed his issue.
Let us know if you find a fix that works.
Kooks Signature Series Headers 1-3/4 stepped to 1 7/8, Kooks 3" High Flow Cats, Vararam OTR Cold Air Intake, JRE Performance Tune, RX Catch Can, RX Oil Breather, LSR Tri-Ax short throw shifter, AAC Red/White Halos and Fog Rings, AAC Knight Rider Scanner Bar
02-11-2011, 05:01 PM | #3 |
The wait is over!
Drives: 2010 Camaro, IOM, L99, Auto Join Date: Mar 2010
fatmat rattle trap - 80mil thick, butyl adhesive, aluminum backing. you can probably use just 1 sheet for your lid, 33.00
second skin makes a good deadener too
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener |
02-11-2011, 05:09 PM | #4 |
Thanks
Thank you guys for your input. I will post the fix when completed.
02-12-2011, 11:12 AM | #5 |
Drives: 2011 ss/rs Join Date: Jan 2011
everyone spends so much money going out and buying this type of sound deadening. While some of it is alot better, the one that topdown shows you can get from any hardware store. The stuff i use is called peel and seal. Its in the roofing section at the home depot by my house. But there are alot of different brands.
02-12-2011, 08:09 PM | #6 |
Go to Lowes or Home Depot and get some door/window weather strip. Line the trunk where it lays on the window.
http://www.camaro5.com/forums/showth...44#post1506844
02-13-2011, 03:33 PM | #7 |
The wait is over!
guys - no one wants to hear it, but peel and seal is NOT the same.
you dont have to take my word for it, god knows I havent always taken the word of those in the know... but over the last 20 years, I have used pretty much every kind of peel-n-seal, snow roof, henry's, rhino-liner, etc... Its not my car your trying to work on... its yours. but, being that I HAVE used every kind of cheaper sound deadening option I could find and instead go back to the stuff like Rattle Trap should say something. you can spend 20.00 on 6 or 7 layers of peel-n-seal and hope that it all sticks and doesnt melt, or you can spend 35.00 on a butyl based vibration solution and not have to worry about it at all. I spent 35k on my car, spending 35.00 more on a real deadener instead of roofing material didnt seem like its enough to break the bank. Now... having said all that... I do recommend that if guys are looking to save a little cash, you can use 3-4 layers of Peel-n-seal on the floor of the trunk or the floor of the cab (though your still running the risk of stink), but at least there it wont run, drip, or release from the panel and fall.
Ordered - 4/17/2010
02-13-2011, 06:33 PM | #8 | |
02-13-2011, 06:58 PM | #9 | |
The wait is over!
I still cant believe how much that rear shelf moved in your video.
Ordered - 4/17/2010
Delivered - 5/29/2010 AlphaDamp CLD Mat - Get more Sound Deadening with less Sound Deadener Last edited by Topdown; 02-13-2011 at 07:10 PM. |
02-13-2011, 07:01 PM | #10 |
It sucks and now, over time random stuff inside the cabin will vibrate including the rearview mirror. With one 10 W7. :(
02-17-2011, 12:42 AM | #11 |
Drives: 2010 Red Jewel 2SS/RS Join Date: Dec 2010
I had the same problem! I installed fatmat on every surface of the trunk, but where the trunk and window met still rattled. So, like JSC81 mentioned, I used weather strip, and ran it along that seal, and bada-bing-bada-boom, problem solved!
Thread Tools | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Weird Rattle in trunk??? | mycamaroisred | 5th Gen Camaro SS LS LT General Discussions | 16 | 10-27-2010 05:47 PM |
lil help please trunk rattle! | Santos | 5th Gen Camaro SS LS LT General Discussions | 16 | 04-06-2010 12:32 PM |
trunk rattle.... | spectrepig | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 8 | 12-23-2009 02:46 AM |
Trunk Lid Rattle | Slake | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 4 | 10-18-2009 02:07 PM |
Rattle in the trunk!!! Not from the spoiler!! | SS Mike | 5th Gen Camaro SS LS LT General Discussions | 9 | 09-15-2009 07:01 PM |
