Old 09-18-2024, 10:26 PM   #1
winged1
Drives: 2016 2SS Auto
2016 SS Eibach Pro Springs Horrible Ride
As the title mentions. I installed eibach springs and now the car is stupid stiff and bouncy. It’s to the point that it’s fairly dangerous going over dips or bumps at speed. I had it aligned at the dealer but didn’t help. Should I just go back to stock or are there better options out there? Any feed back is appreciated. Thanks
winged1 is offline   Reply With Quote
Old 09-18-2024, 11:59 PM   #2
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
When I installed the v6 Eibach Pro springs, I also used SS (FE3) shocks. The ride was very rough but great in corners. Depends on what you want from the suspension, if you just want a lowered height with a good ride then these springs are not for you, may need to look at coilovers if that's the case
2016 1LT v6
- Totaled
Happiness: Infinite
Old 09-19-2024, 07:05 AM   #3
winged1
Can you recommend a good coil over set up that won’t blow my wallet up? Thank you. FYI the ride is literally ridiculous. It feels like the car catches air on some bumps.
Old 09-19-2024, 07:21 AM   #4
cdb95z28
cdb95z28's Avatar
You need to time the rubber suspension bushings.
Every rubber bushing is now in a state of twist or bind at the new static ride height. This includes the anti roll bar mounts. To relieve the stress each rubber bushed suspension joint needs to be loosened, at ride height, then retightened. This will reset each bushing to a new zero bind state. Note that on the Gen6 there are some joints that are a spherical ball type joint. They do not need reset. They are self resetting.
Coming from the Gen5 community and now as a Gen6 SS 1LE owner, I see less conversations about timing the bushings among the Gen6 groups. I'm willing to bet most guys doing springs haven't done it. GM calls out timing the bushings in the service manual as tightening the suspension joints at ride height. So this is something that is important. Yeah, it adds time and cost to just doing drop springs but do it once, do it right.
Most suspension fasteners are torque to yield (TTY) one time use per GM. Each bolt should be replaced every time they have been fully tightened.
Is your car MagRide equipped? If so, then the ride height sensors also need rezero'd. There are relatively cheap scan tools on amazon that can do this.
https://www.camaro5.com/forums/showthread.php?t=153188
Old 09-19-2024, 07:25 AM   #5
cdb95z28
cdb95z28's Avatar
Your SS may have more rubber bushed joints than I described in the below post. But, there are links there for fastener torque specs.
https://www.camaro6.com/forums/showp...9&postcount=10
Old 09-19-2024, 07:48 AM   #6
SSShark
SSShark's Avatar
Drives: '23 1SS Sharkskin A10
Great info cdb95z28. Quick question; I'll be installing the GM lowering kit on my 23 SS shortly. Does the rubber suspension bushing process also apply?
Edit: Didn't mean to hijack.
SSShark is online now   Reply With Quote
Old 09-19-2024, 07:56 AM   #7
clg82
Drives: 2020 Camaro ZL1
This^^ a little research prior to installation would have helped alleviate this.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| AWE Touring Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21
Old 09-19-2024, 08:14 AM   #8
SSShark
SSShark's Avatar
NM, I found the answer.
Old 09-19-2024, 03:15 PM   #9
winged1
Awesome thank you. So much for following the instructions to t. I’ve never had to do this on any vehicle I’ve lowered. Anyway I really appreciate the help. I hope this takes care of the issue.
Old 09-19-2024, 05:51 PM   #10
atx_traveler
Drives: blue velvet
winged1 - how many miles are on your car? do you have MRC? mine is non-MRC and after 5 years with the Eibach springs I can feel the shocks deteriorating. Going to pick up some Konis soon.
atx_traveler is offline   Reply With Quote
Old 09-24-2024, 02:32 PM   #11
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Oh Boy I am in the same ass position as you. This is my second 2017 2SS. First one had MRC and when I lowered it, it was great. My car now is on a set of Eibachs, every adjustable control arm, etc, from BMR out back, and is non-MRC. I hate driving the car. I figured it was the non MRC shocks but now I am second guessing. I also took it to a local dealer that specializes in GM performance and I asked for a "street" alignment and they dialed it in. It is like I cut the springs. I have considered going back to stock because I hate it, but damn it looks good. LOL
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 09-24-2024, 04:09 PM   #12
cdb95z28
cdb95z28's Avatar
BMR arms out back.....poly or sphericals?
Old 09-24-2024, 04:27 PM   #13
teddyca
teddyca's Avatar
Sorry brother I dont even know what that means lol. I assume "spherical" refers to the adjustable stuff with the heim joints, which is what I have. I basically have the following from BMR, I be missing a couple parts but theres a lot of red. adjustable control arms, trailing arms, toe rods, sway bars. I had the non adjustable stuff and sold it all here hoping the adjustable would help and well nope. Shit I even bought all the stuff I replaced back from another seller because I tossed my stuff sure I would never go back to stock. LOL
Old 09-24-2024, 06:05 PM   #14
Texas1ss
Texas1ss's Avatar
Drives: 2016 Black 1SS, M6, NPP, Mag Ride
I wonder if it's even possible to keep the ride quality of an SS with MRC and dropping it a little bit. I like the look bigtime, but I don't want to get tossed around. I'm in Tour mode suspension on every mode, whether Sport or Track, 100 percent of the time. I'll have to check into it.
Texas1ss is offline   Reply With Quote
