Old 09-18-2024, 08:46 PM   #1
Colin101234
Colin101234's Avatar
Drives: 2017 2SS 50th HCI
Exclamation PSA TO ANYONE WHO CUTS OFF THE DOD SOLENOIDS
Gunna start by saying DO NOT MAKE THE SAME MISTAKE AS I DID. If you cut off the solenoids it leaves and open port on the oil pressure sensor ( This has nothing to do with the dod block off plugs) You will lose a lot of oil pressure and it will spew oil into you pcv valve and dump ALOT of oil into you intake manifold. Take my word for it and dont make the same mistake as I did!!!!!
50th Anniversary Camaro, 1 7/8 headers, lt2 IM, CAI CAI, Frankenstein ported/milled heads(.025), Ductile Valve seats, Inconel EX valves, FED .700 dual springs, NON VVT Custom Cam Motion Cam (224,242[.638/.647] 114.5+3), CHE Trunions, Caddy R Lifters, 3 In catback, Borla atak mufflers, GPI tune.
Colin101234 is offline   Reply With Quote
Old 09-18-2024, 08:47 PM   #2
Colin101234
No one tells you this and even Texas speed told me it would be ok. Which ITS NOT. Now I'm stuck buying a new valley plate and new head gaskets and bolts because I pulled the heads to diagnose the issue
Old 09-19-2024, 11:31 AM   #3
Hostile_1LE
Hostile_1LE's Avatar
Drives: 2020 Camaro SS 1LE | Satin Steel
Do you mean remove all the plastic valving and stuff from the bottom of the factory valley plate / VLOM? Why would you do that anyway and not just rely on the dod plugs?
HCI | GPI SS3 | E85 | xxx whp \ xxx tq
Hostile_1LE is offline   Reply With Quote
Old 09-22-2024, 08:49 PM   #4
Colin101234
I mean removing the plastic solenoids but also removing the entire metal bracket and studs so it's a clean plate. You can't do it without issues
Old 09-22-2024, 09:09 PM   #5
Joshinator99
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Plenty of DOD delete valley covers on the market, not worth the hassle of running without one.
2017 Chevy Camaro 2SS A8 Whipple 3.0, Mast Black Label heads, ATI 8L90, Fore triple in-tank pumps, 112mm TB, LPE +52% injectors & BB HPFP, 15” conversion 1059 WHP/944 WTQ, 9.48@150
dod, mistake, solenoids, valley
