Old 07-03-2024, 05:55 PM   #15
vigg
vigg's Avatar
Drives: 23 Camaro 2SS 1LE
Attached pics here for reference..
Thanks!
Vigg
2023 Camaro 2SS 1LE 6MT
2019 Mustang GT (Sold)
2012 Audi A6 (Sold)
2014 Camaro 2LT RS (Sold)
2011 Acura RL (Sold)
2009 Acura TL (sold)
vigg is offline   Reply With Quote
Old 07-15-2024, 10:11 PM   #16
GreyGhost702
Drives: 2019 Camaro 1SS1LE
That’s exactly what my thrust bearing looked like. GM considers that prelude to failure? Either they made an entire production line of lemons or they jumped the gun on calling it an early failure. That thrust design is downright shitty. The thrust sides are barely tack welded to the main bearing, it wouldn’t take much abuse to knock the tack off and the only thing that keeps the thrust in place is lubrication and the 3 keeper slots on the bearings.
Some pics of my bearings. I only tore my engine down to forge and stud it, there was nothing wrong with it prior to removal. Just prepping it for boosted life. I didn’t take a pic of the thrust separated, but the rearward face of the thrust bearing was detached from the main and only held in place by the keeper slots.
And here are some of the other engine I was going to use but the thrust had actually failed and spun.
On my forged build I went with the ACL bearings, they offer a full 360 thrust bearing and it’s a 1 piece design unlike the OEM seems to be truly a 3 piece design.
2019 1SS1LE M6 Shadow Grey Metallic
ProCharger D1X Race Kit - 4.25" Pulley || GPI Pistons/Rods - ACL Bearings - ARP Hardware || LME Timing Chain Guide || Katech C5R Timing Chain || Katech OE Spec Billet Oil Pump || OE Ported Heads || CHE Trunnion Upgrade || BTR 220 Cam - BTR .660" Dual Springs - GM Racing "Caddy" Lifters - BTR Chromoly Pushrods (7.825") || ATI Balancer || LT4 Injectors || LT4 HPFP || JMS BAP || DSX Flex Fuel || LT2 Intake Manifold || LTH (Catless) || Stainless Works Redline Series NPP || 91 + Boostane
7/26/2024 Tuning in progress
GreyGhost702 is offline   Reply With Quote
Old 07-16-2024, 03:48 PM   #17
dpevans
Drives: 2024 Riverside Blue 2SS 1LE
Originally Posted by VR Baron View Post
That sucks. Hope all is taken care of. I have a 2021, built 10/1/2020 and is a M6. Back then I had to worry about the valve springs being bad from a bad batch affecting July- September cars, Camaros and vettes. I have a tech friend check the car I was buying and no recalls or tsb’s, so lucky. I to have a ticking sound but that’s fuel injection noise in the rails, my fifth gen had same. 15000 miles on the car and over three years of autocross 1-2 gear high rpm use and no issues nor any oil consumption.
Guess it was a Wednesday built car..lol
Isn't that weird, Mine has 5,900 and been tracked 4 times and oil changed at 500, 2,000 right before 2cd track event and getting ready to do another and it has not burned any oil. I am using the Super Car. I am shocked that Chevy built an aluminum motor and I got one that doesn't burn oil, my NorthStar I had to put a quart in every time I pulled in the driveway.
dpevans is online now   Reply With Quote
Old 08-22-2024, 03:29 PM   #18
23VIVIDORANGE1LE
Drives: 2023 Camaro SS 1LE
I have your triplet.... This is the very reason I'm building a 416" for my Bad Pumpkin.
23VIVIDORANGE1LE is offline   Reply With Quote
Old 08-22-2024, 03:47 PM   #19
DaveC113
DaveC113's Avatar
Drives: 2018 Camaro 1SS 1LE
Originally Posted by dpevans View Post
I think thats why when the car warranty is over I am doing the AFM delete.
I was going to until I saw what was involved. LT1 isn't a typical easy to work on SBC, heads have to come off to replace lifters and my tech said it was going to be ~$3k in labor. At that point it's hard to skip doing cam and some head work, and the cost starts getting out of hand.
Old 08-22-2024, 04:08 PM   #20
m6-lt1
m6-lt1's Avatar
Drives: 2023 Chevrolet Camaro 2SS 1LE
I don’t think you can delete the afm without actually changing the cam. If you can I’d actually be willing to do that. And yeah unfortunately since at least the LS1 days the heads now unfortunately need to come off for a lifter swap. Sucks because I think lifters are pushrod engines biggest problems in general (Ford and dodge have lifter issues as well) and the average gas station mechanic used to be able to swap lifters as they were under the intake a looooong time ago.
Current: 2023 2SS 1LE
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
m6-lt1 is online now   Reply With Quote
Old 08-22-2024, 10:27 PM   #21
GreyGhost702
m6 is correct, you'd need a non-AFM OE-spec cam at a minimum, can't just delete the AFM without doing it. In that respect, it's not the easiest to work on but it's not a horrible job either. Having had the engine out by myself, if I had to do just a cam swap, I could do it with the engine in the car. Some provisions would need to be made of course, to make the job easier. I fully removed my firewall cowling when I did my engine build. Made access in the engine bay 10x better. There's so much shit hiding under the cowl it's a wonder how some folk manage with the cowling in place. It must be quite the battle. This method also makes removal/installation of the heads a breeze as well. There's also a bit of a shortcut in moving the radiator out of the way without removing it from the car when it comes to removing/installing the cam.
I would not say it's a waste of time to do a cam swap, whether it's swapping for an AFM Delete OE spec cam or otherwise. Is it as easy as an LS platform, probably not. Definitely gonna take more time. I think a cam swap is easily do-able over a weekend, done by an enthusiast grade mechanic/tools/garage. Taking your time with lots of breaks, 12-14 hours. If you know your Gen 5 LT1, have all your parts and tools lined up and ready to go, 6 hours.
Yeah, it's definitely not a simple CAI/Muffler job.
Old 08-23-2024, 08:20 AM   #22
m6-lt1
m6-lt1's Avatar
Yeah that’s definitely above my abilities haha. Been debating when warranty is up throwing the LT5 cam in it as that’s a non dod oem cam. It’d be a lot of money for basically no power gain though but I do like to stay as oem as possible.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 08-23-2024, 12:21 PM   #23
DaveC113
DaveC113's Avatar
Hmmm, doesn't sound too bad. I could use a bit more power and a higher redline... Maybe I'll do it over the winter.
That $3k in labor seems like it's a lot of hours, but with many shops charging crazy-high hourly rates $3k doesn't go that far.
Old 08-26-2024, 11:41 AM   #24
242ss1LE
Drives: 2024 2ss 1le m6 vom
I started hearing ticking noise from engine bay after starting the vehicle two days back so took it to the dealership. They said camshaft has been damaged but car has only 4K miles. They ordered the part and said it will be fixed under warranty.
Should I be worried that this happened within the first one year of purchase and please advise whether I need to ask the dealership to check/replace anything else that might have been damages b/c of this issue.
Appreciate the help!
my 24 does not tick but it has recently felt bogged down in first was this happening to you before the tick mine only has 2600 miles on it but i know it does not feel right when i launch car.
242ss1LE is offline   Reply With Quote
Old 08-26-2024, 12:34 PM   #25
DaveC113
DaveC113's Avatar
Try turning the nannies off and see if it still bogs (but be careful!).
Old 08-26-2024, 07:41 PM   #26
m6-lt1
m6-lt1's Avatar
Were you driving in track mode? I noticed it takes a little more throttle to get going in track mode than in sport. It will bog a bit if you don’t give enough gas to get going in first in track mode. This was present on my 16 SS as well. Try driving in sport mode.
Prior:
2016 Camaro 1SS
2007 Mustang GT
2008 Civic Si
Old 09-19-2024, 01:26 AM   #27
Azmedian
Azmedian's Avatar
Drives: 2020 Chevrolet Camaro 2SS/1LE
Too late im sure but did they change the lifters
2020 Camaro 2SS 1LE
1968 Camaro
Az
Azmedian is offline   Reply With Quote
Old 09-19-2024, 07:46 AM   #28
To what, non-DoD lifters? That isn't the OE spec, I think on a warranty job a dealership would only replace the old ones with the exact same setup that the car came with.
23 2ss 1le, camshaft problems
