Old 01-14-2020, 02:41 PM   #1
94boosted
94boosted's Avatar
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150
Race Capture CAN Channels
Hi All,
I recently acquired an Autosport Labs Race Capture MK2 as I'm looking to get a bit more detailed with my data for autocross and track days.
Trying to determine what the CAN Channels would be for Steering Angle, Throttle Position and Brake Pressure but having no luck. Any chance anyone on here knows?
Thanks in advance.
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold
94boosted is offline   Reply With Quote
Old 01-21-2020, 05:24 PM   #2
94boosted
94boosted's Avatar
Bump, anyone?
2017 - SS 1LE
Old 01-21-2020, 10:04 PM   #3
clyde
clyde's Avatar
Drives: broken
This is what I'm using with a RaceCapture Track Mk1 on my turbo. Pretty sure it will work for you.
CAN ID: 485
Mask: 0
Sub ID: Disabled
CAN Bus: 1
Offset: 1
Length: 2
Bit Mode: unchecked
Source Type: Signed
Endian: Big
Formula: Raw X -0.0625 / 1.0 + 0.0
Units Conversion: No Conversion
clyde
Team WTF?!
what are you gonna do? :dunno:
clyde is offline   Reply With Quote
Old 01-24-2020, 02:30 PM   #4
94boosted
94boosted's Avatar
CAN ID: 485
Mask: 0
Sub ID: Disabled
CAN Bus: 1
Offset: 1
Length: 2
Bit Mode: unchecked
Source Type: Signed
Endian: Big
Thank you Clyde, is this for steering, brake or throttle?
2017 - SS 1LE
Old 02-02-2020, 07:10 PM   #5
clyde
clyde's Avatar
Drives: broken
Oh, I think I only read as far as "steering" in your original post, so that was steering.
Brake:
CAN ID: 241
Mask: 0
Sub ID: Disabled
CAN Bus: 1
Offset: 1
Length: 1
Bit Mode: unchecked
Source Type: Unsigned
Endian: Little
Formula: Raw X 1.0 / 1.7 +0.0
Throttle
CAN ID: 201
Mask: 0
Sub ID: Disabled
CAN Bus: 1
Offset: 4
Length: 1
Bit Mode: unchecked
Endian: Little
Formula: Raw X 100 / 255.0 + 0.0
clyde
Team WTF?!
Old 02-03-2020, 09:55 AM   #6
94boosted
94boosted's Avatar
Brake:
CAN ID: 241
Mask: 0
Sub ID: Disabled
CAN Bus: 1
Offset: 1
Length: 1
Bit Mode: unchecked
Endian: Little
Throttle
CAN ID: 201
Mask: 0
Sub ID: Disabled
CAN Bus: 1
Offset: 4
Length: 1
Bit Mode: unchecked
Endian: Little
Thank you!
2017 - SS 1LE
Old 02-03-2020, 08:28 PM   #7
clyde
clyde's Avatar
Drives: broken
Thank you!
Make sure they work before you thank me!
I didn't just make up "Team WTF?!"
clyde
Team WTF?!
Old 04-21-2020, 02:36 PM   #8
94boosted
94boosted's Avatar
FYI if anyone is using Race Capture on their Gen 6 Camaro SS the above CAN channels work beautifully for steering, brake pressure and TPS.
Huge thanks to Clyde!
2017 - SS 1LE
Old 04-22-2020, 09:54 AM   #9
94boosted
94boosted's Avatar
2017 - SS 1LE
