Old 05-22-2017, 10:13 AM   #15
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Looks good for a track set up.
It will do wonders for your paint job if you drive that on the street
I like the +36 on the back. Always thought the +43 was conservative.
Imho 11 on the back and 10.5in the front is not square.
You potentially change the characteristics of the tire using different wheels.
Better be running some PPF and rock guards that's for sure! Definitely not a true 'square' set up as the wheels are different, but I didn't feel comfortable finding a balance between the front and the rear that would allow an identical wheel, so the next best thing was to fit a 305 up front using whatever means necessary. This will at least allow the tires themselves to be swapped around, though I doubt I will be doing that often. The main goal here for me was not necessarily square, but to get more tire up front.
seanblurr is offline   Reply With Quote
Old 05-22-2017, 10:26 AM   #16
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
Old 05-22-2017, 10:34 AM   #17
Provoste
Provoste's Avatar
Drives: E46 S54 race car, 964C2
I'd be interested to see what the front wheels look like mounted on the rears. I'm kicking around getting set of 19 x 10.5 square. Apex offers 22ET and MRR obviously offers 14ET.
Provoste is offline   Reply With Quote
Old 05-22-2017, 10:37 AM   #18
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
MRR will cut yours anyway you like
Old 05-22-2017, 11:11 AM   #19
TrackClub
TrackClub's Avatar
Looks like an excellent fit. Congrats Sean!
Others: note Sean pushed out the R offset to maintain F to R track width balance as close to stock as possible (based on wider F wheel).
I think that's were some folks get messed up not paying attention to this detail. What alignment specs are you at Sean? Lookig fwd to your on track reports!
Old 05-22-2017, 11:16 AM   #20
MRRWheelsInc
Drives: Camaro
Smile
Originally Posted by seanblurr View Post
Well folks, here it finally is. These are MRR FS01 19x10.5 +14 and 19x11 +36 wheels with 305/30/19 NT01's. This is a track specific wheelset on my 1LE and will see very little street time. Even so, for a 10.5 +14 front wheel, the poke is a lot less than I thought it would have been. Some of you I'm sure will complain () but poke is a non-issue on the track and looks come second. I was jumping around with different wheel and tire ideas and was skeptical at first of running a square tire, but ultimately after my own testing on track I felt a square setup would be superior to a staggered setup. Technically this is not a true square set up as the wheels are different, but my main goal was to get more tire up front. If needed, I will at least be able to swap around tires at my local tire shop. I have yet to drive it on track, so this may or may not be the answer. For those curious, I came to these offsets by way of trying to maintain the same, oem, inner strut clearance on the front. I decided to drop the rear to +36 to try and maintain some semblance of the stock track width. Special thanks to MRR wheels and PK Auto Design for being able to quickly make the wheel to my exact specs. Anyhow, here ya go.
Sean, Honestly all I can say is Wow,I was doing the math ever since you did the order and I could not picture how it would fit, Straight up im taking my hat off for you much respect. this set up was not a sponsorship and it was absolutely nothing for marketing it was your hard earned money and your specified specs and we definitely thank you for letting MRR Wheels be part of your project, damn great job !!
send us some more pics when ever you get a chance and keep us posted on your track experience.
MRRWheelsInc is offline   Reply With Quote
Old 05-22-2017, 11:18 AM   #21
MRRWheelsInc
Drives: Camaro
Yup, all of our Flowforged wheels are cut to clients specified specs or as required by vehicle, we can do aggressive fitments, or conservative, basically which ever you need for your project.
we complete all of our custom work with in 5-7 days max.
Old 05-22-2017, 11:19 AM   #22
cleoent
cleoent's Avatar
Drives: 16' Camaro E-Force SS
I think it looks great! My only complaint is 4x4 stance.
Leo
2016 e-Force 2SS
Instagram @cleoent
cleoent is offline   Reply With Quote
Old 05-22-2017, 11:20 AM   #23
TrackClub
TrackClub's Avatar
Never too late to make it a "sponsorship deal". The guy figured out proper offsets for ya "pros" here, proved a concept and now you'll sell a ton of them. Just sayin....
Old 05-22-2017, 11:27 AM   #24
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Is it true that you advise to use no more than 110 lb/ft torque for the lug nuts?
Thanks in advance
glamcem is offline   Reply With Quote
Old 05-22-2017, 11:40 AM   #25
LSmith353
LSmith353's Avatar
Drives: 2015 Ultimate Track SS
Looks fantastic. +36 on the rear puts the outside edge of the rim in exactly the same spot as a 10" wide with +25. It looks like a race car.....
You've helped me make up my mind!
2015 2SS Ultimate Track Camaro
https://www.racingjunk.com/news/2014...ack-camaro-ss/
2016 2SS M6, MRC, NPP, Nav, Sunroof -- SOLD
2010 2SS/RS M6 -- SOLD
LSmith353 is offline   Reply With Quote
Old 05-22-2017, 11:49 AM   #26
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
I guess I'm tracking one sexy 4x4 then
Old 05-22-2017, 12:38 PM   #27
TrackClub
TrackClub's Avatar
I think it looks awesome!
Old 05-22-2017, 12:39 PM   #28
TrackClub
TrackClub's Avatar
Thanks in advance
I am all ears on this one as well.
