Old 07-18-2021, 09:43 AM   #1
FoundNemo
Drives: 2019 ZL1
Boost lvl for a 2650R / 90mm Pulley / OEM Lower / 103mm TB / 2" Longtubes
Just curious, what boost level are folks seeing with a 90mm pullied 2650R on an OEM lower pulley, Rotofab intake, 103mm TB, 103mm blower snout, 2" longtubes and all otherwise stock setup?
FoundNemo is offline   Reply With Quote
Old 07-18-2021, 11:17 AM   #2
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
16psi +
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 07-18-2021, 11:39 AM   #3
IneedAZ
IneedAZ's Avatar
Mine is 16 but with the ATI 14% lower
Old 07-18-2021, 12:09 PM   #4
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
You have a cam. Technically you should be lower, unless 16psi is when its cold.
Old 07-18-2021, 12:16 PM   #5
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This is the 2650, 90mm, headers, green cats, 103mm intake, cat back, roto fab.
Cold weather 16.6 psi.
Old 07-18-2021, 12:23 PM   #6
FoundNemo
Drives: 2019 ZL1
Looks like my buddy will be going with a 95 or 100mm pulley to keep it totally safe for fueling limits then. Thanks.
Old 07-18-2021, 12:58 PM   #7
IneedAZ
IneedAZ's Avatar
My components are in the sig
Old 07-18-2021, 02:52 PM   #8
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Yes but hes asking what the boost is with stock engine, no internals.
Old 07-18-2021, 02:57 PM   #9
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Stock 90mm is fine, he will be close/right at limits. If hes in an area that doesn't have 93 may need to reduce timing rather then otherwise. A 95mm will work too. A 100mm probably isn't worth putting on as you'll be losing 3-4psi of boost.
I think i made like 660/665 or something on the 90mm @ 17degrees of timing up top.
Old 07-20-2021, 12:23 AM   #10
PureZL1
PureZL1's Avatar
Drives: 2018 A10 ZL1
I hit 13 psi with a 90mm upper, oem lower and stock tb, stock snout also 14 on 85mm with the same build, seems like i am very different than everyone else but its happening for me.
PureZL1 is offline   Reply With Quote
Old 07-20-2021, 12:35 AM   #11
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Ya that's odd. do you have any data logs?
Old 07-20-2021, 09:45 AM   #12
laynlo15
laynlo15's Avatar
Drives: 2022 Lt1 A10
Stock lower should be at about 13-14 depending on elevation
Old 07-20-2021, 02:21 PM   #13
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
That definitely isn’t right. You can see many posts from other tuners all over where the 90mm, stock lower are all hitting 16psi. (Sea level) my log as well.
Old 07-20-2021, 04:23 PM   #14
PureZL1
PureZL1's Avatar
Unfortunately i don’t, i am setting up a new build with a cam and 9.17 lower hope it goes well.
