09-22-2018, 02:20 PM | #1 |
Drives: 2017 ZL1 Join Date: Jan 2017
BMR rear suspension/cradle installed on my ZL1
Hey,
I finally finished getting all the BMR rear suspension components installed. I wound up doing the upper control arm and upper/lower trailing arms. TuneTime Performance did the cradle lockout when they had my car in the shop recently. Overall the rear feels like it is "one" with the car, amazing. I would suggest it highly to anyone taking to the track, drag racing, or have a ZL1 with extra whp. I put a jackstand under the rear arm to place some load on it. This helped to free up the components so you could simply remove the bolts and drop them out. Some of the bolts/nuts are a little hard to get at so plan on using some hand tools and not just your impact. You will have to zip tie up one line (abs) to the upper control arm.
09-22-2018, 03:10 PM | #2 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
How did it feel with just the rear cradle done? Night and day now that the arms as done as well? They really look trick on there.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
09-22-2018, 07:23 PM | #3 |
The rear cradle made the most impact.
09-22-2018, 10:33 PM | #4 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
I concur.
I just had the ZL1 1LE solid rear cradle bushing kit done last week. Between that and a track alignment, it plain kicks ass now in the handling department. The rear-end feels solid and as the OP said, one with the rest of the car. 100 MPH sweepers are a one handed affair now. No drama, no chasing the rear, no rear side to side motions trying to spoil your line in a turn. I do not feel a need to do the arms at all. The rear cradle is where the biggest weakness is on these cars.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
09-23-2018, 10:19 AM | #5 |
Drives: ZL1/335i Join Date: Apr 2014
09-23-2018, 12:32 PM | #6 |
1LE Convert
Drives: 2018 ZLE Join Date: Apr 2017
What's the purpose of the arms? Do they weigh less than stock? Otherwise, I imagine GM has engineered them to handle the loads they are needed to handle, if not at the lightest possible weight (stamped steel).
09-23-2018, 12:44 PM | #7 |
Drives: 2018 ZL1, 2018 Tahoe RST Edition Join Date: Aug 2018
Where did you buy rear cradle kit?
09-23-2018, 12:57 PM | #8 |
I did the GMPP ZL1 1LE solid rear cradle Bushing Kit, I got it from Wildhammer Motorsports.
If you go the BMR lock-out Kit, I think you can also get that from Wildhammer, and if they don't have it, you can get it directly from BMR. I decided for me, even though it was going to cost more in labor, that I wanted 100% of the movement gone and not just 80-90% of it that the lock-out kit gives you. For most, I am sure the lock-out kit will do, but I am VERY anal about handling and feel and I wanted 100% solid bushings back there. I do not regret that choice and am reminded everyday that I made the right decision.
Current:
09-23-2018, 06:00 PM | #9 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Any negative trade offs with the rear cradle kit? More NVH?
09-23-2018, 06:11 PM | #10 |
I have no regrets, just do it.
09-23-2018, 06:58 PM | #11 |
ZERO. I notice no increase NVH and no increase in noise. I really thought there would be some penalty, but to my ear and butt-o-meter, there was no negative offset.
It is a no brainer and honestly I feel GM should have at least given all the 1LE's this upgrade, if not the entire line up.
Current:
09-23-2018, 07:32 PM | #12 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
If I was doing it myself I would do the lockout kit. Looks easier to install. Removing the bushings looks real easy on you tube but it's a total pain. I did that to my 5th gen.
09-23-2018, 07:37 PM | #13 | |
It's more a question of do you want 100% movement gone, or 80-90% gone. I choose 100%, but I hear good things about the lockout kit, no first hand experience though.
Current:
09-23-2018, 07:43 PM | #14 |
LT4 M6
It took me a good 12 hrs to do mine. But part of the problem was me torch didnt get hot enough to melt the bushings so I had to buy another torch.
I can get stuff done right but wouldn't make any money as a mechanic. I'm slow. |
