Old 08-14-2018, 01:28 PM   #1
clayn
Drives: 2017 Camaro RS
2017 Camaro RS Bolt Pattern
I have a guy who wants to but my extra set of tires and rims off of my 17 RS, but he wants to know if they’d fit on an 84 camaro. Would the bolt pattern be the same?
clayn is offline   Reply With Quote
Old 08-14-2018, 01:55 PM   #2
Bodyslide
Bodyslide's Avatar
Drives: Traded in 2016 BLUE VELVET 2LT RS
Info here, not sure it will fit. Good Luck
https://www.wheel-size.com/size/chevrolet/camaro/2017/
Bodyslide is offline   Reply With Quote
Old 08-14-2018, 02:29 PM   #3
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Bolt pattern is "slightly" different - but it will fit. The bolt pattern on 6th Gens is 5x120mm - same as BMW's... I have BMW wheels (5x120mm) on my 99 Z28 and that car has the same bolt pattern as the 84 camaro (5x120.65mm) and have had no issues with them for 2 years now. Just make sure to use hub centric rings, thats very very VERY important. You run the risk of breaking lugnuts if you don't use them.
Now offset and width may be a different story, that you will have to research on your own.
Need4Camaro is offline   Reply With Quote
Old 08-14-2018, 02:31 PM   #4
CH.CRAFT
CH.CRAFT's Avatar
Drives: 2018 HOT WHEELS SS 6 SPEED COUPE
1984 BOLT PATTERN IS 4 3/4”=120 MM
2017 BOLT PATTERN IS 121 MM
1 MM=0.0394”
I WOULD THINK THAT THEY WILL BOLT UP, BUT THE TIRES AND OFFSET WOULD HAVE TO BE CHECKED.
2017 QUICK 16 TRACK CHAMPION
STATE CAPITOL RACEWAY
RACE TRACK CHAPLAIN FOR 30+ YRS
CH.CRAFT is offline   Reply With Quote
Old 08-14-2018, 04:17 PM   #5
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Noooooo! With conical lug nuts, "close" is not good enough.
Old 08-14-2018, 05:06 PM   #6
clayn
I appreciate the replies. Thanks guys!
Old 08-14-2018, 06:54 PM   #7
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
1 MM=0.0394”
looks like the 17 bolt pattern is 5x120 mm same as the 4 3/4 bolt pattern
lt4camaro is offline   Reply With Quote
Old 08-14-2018, 09:18 PM   #8
CH.CRAFT
CH.CRAFT's Avatar
THE CHART I LOOKED AT I BELIEVE IS WRONG, IF YOU CONVERT MM TO INCHES 4.75 INCHES IS 120.65 WHICH WOULD BE THE SAME BOLT PATTERN FOR ALL CAMAROS. I THINK THE DISCOUNTED WHEEL CHART I LOOKED AT ROUNDED 120.65 UP TO 121.
2017 rs, bolt pattern, wheels
