Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 07-08-2016, 11:23 AM   #1
woundedcyborg
Drives: 2010 LT
Novice Tire Question
I know there are tons of tire threads on the site but I find it to be a bit overwhelming not knowing anything and need things dumbed down a bit further.
I plan on buying 20 inch stock 2015 camaro rims locally if i end up buying this 2010 1LT (currently in price negotiations), I want to use these to put winter tires for easy swapping.
What size tires do I need to search for? Do 20inch rims=20 inch tires?
I know blizzaks(sp.?) and scorpions are the go to winter tires but i wanted to see if there are perhaps some (cheaper) alternatives.
Thanks
woundedcyborg is offline   Reply With Quote
Old 07-08-2016, 01:40 PM   #2
jrhagen
Drives: Camaro
I would recommend going to NTB or Discount Tire or whatever national store is near you to see what your options are.
jrhagen is offline   Reply With Quote
Old 07-08-2016, 02:05 PM   #3
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Front rims get 245 45 R20 and rear rims get 275 40 R20 tires . The way the size works Is first number is how wide the tread is (245 mm ) middle number is % of the first number in side wall height (45% of 245 mm ) third number is the rim size (20) .the R means it's radial (steel belted
davidscamaro is offline   Reply With Quote
Old 07-08-2016, 03:09 PM   #4
Rudy@Tirerack
Rudy@Tirerack's Avatar
Drives: 1-800-428-8355 X4664
For winter I actually suggest running the 245/45R20 on all 4 corners.
Rudy@Tirerack is offline   Reply With Quote
Old 07-08-2016, 03:36 PM   #5
jrhagen
Drives: Camaro
The middle number is actually the percentage of the he tread divided by 2.
Old 07-08-2016, 08:04 PM   #6
woundedcyborg
Drives: 2010 LT
So when a tire says "19inch" that's referring to the rim?
If you have 20inch rims are you forced to buy 20inch tires?
Old 07-08-2016, 08:08 PM   #7
wrtowman
wrtowman's Avatar
Drives: 2011 Camaro 1SS
yes
2011 SGM Camaro 1SS/RS A6 - Vengeance Racing built/tuned. 590RWHP/560RWTQ, ADM LSA Conversion, 2.5 Grip-Tec, ZL1 fuel pump, ADM FPCM, FIC1000, VRPD2 Cam and LS3 Conversion with all the internal goodies, American Racing 1 7/8 Headers, no cats, SW Retro Cat Back, ADM Intake, AFCO HX, Varimax Pump, Rotofab Reservoir, B&M Transmission Cooler, VMAX TB, Elite Engineering CC, BMR LCAs, Trailing Arms, Toe Rods, DSS 1000hp axles, ZL1 Bumper and Sideskirts, Night Owl Halos, Matte Black 20" Rohana RC-22 with 20x10-275s/20x11-315s, R1 Concept Premier Drilled/Slotted Rotors, Hawk Ceramic Pads.
wrtowman is offline   Reply With Quote
Old 07-08-2016, 09:23 PM   #8
FunkedOut
FunkedOut's Avatar
Drives: Black 2010 SS
FunkedOut is offline   Reply With Quote
rims, tire, winter
