Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Suspension / Chassis / Brakes
Old 12-14-2021, 02:47 PM   #1
southerncarparts
southerncarparts's Avatar
Drives: 2009 Corvette Z06
2016-2019 CAMARO SS AFE CONTROL LOWERING SPRINGS 410-402002-N
When you want to increase the handling of your car the first thing you need to change are the springs. These springs will give you a firmer ride and a lowered center of gravity for better steering response. These springs are Made in the USA and are engineered to optimize the factory shock absorber damping and are compatible with both standard, and MRC "Magnetic Ride Control". On Non-MRC cars, the springs offer a 1.25" front drop and 1.5" in the rear for the perfect blend of performance and style. MRC cars can expect a 7/8" front drop and 1" in the rear. For years of durability and great looks, the springs are powder-coated a special 2 stage tangerine orange. aFe Control lowering springs will increase cornering and handling performance, giving you the confidence to take that turn without adversely affecting ride quality. The lowered stance will transform the way your Camaro looks, as well as offer improved aerodynamics. Designed as a direct fit application these springs require no modifications to the vehicle.
This aFe Control Suspension product is designed and engineered in their Corona, California facility.
APPLICATION: 2016, 2017, 2018, 2019 CAMARO
southerncarparts is offline   Reply With Quote
Old 04-13-2023, 10:09 PM   #2
southerncarparts
Thank You for shopping at https://www.southerncarparts.com/201...parts-com.html
