![]() Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
Valve Spring Change Tips?
I'm preparing to install slightly upgraded valve springs on my 2018 LT1 equipped with 11 psi of LT4 supercharger.
Has anyone done this in the car? Any tips/gotchas? Is compressed air/rope trick really necessary? My Gen I and II motors did not require as long as the piston was at TDC - the valves would not drop excessively. I do have the Blue Grass Gen V Valve Spring Compressor. Thanks!
#3 | |
![]() Drives: 2017 C7 GS M7 / 2017 Camaro SS 1LE Join Date: Dec 2016
#4 | |
Upon examination of the BTR supplied locks - they don't appear to be any different than normal SBC stuff. I know wear/damage can occur that imprints the lock into the valve (likely valve float issues), but I'm hoping I haven't experienced any of that. Appreciate the input.
#5 | |
Interesting. Hope to give it a shot tomorrow and will report back. Thanks.
#7 |
Affirm - only did #1 cylinder thus far.
BTR's installed: ![]() No air / rope tricks needed. Piston at TDC only let the valve drop a quarter of inch or so (more on the exhaust side).
#8 |
Well, down to the last cylinder for the spring change and ended up with this image...what is missing?
![]() Oops... Fortunately, I had eyes on when it flipped off the retainer...fell externally to the engine into the bowels of the engine compartment. So waiting for a replacement...bought 2 weeks of downtime. It was newbie mistake...not employing any catch rags.
#9 |
![]() Drives: 18 2SS 1LE NFG Join Date: Aug 2018
I have done alot of cams and springs and I always put vaseline on them, easier to install and helps keep them from flying off and if the do they stick lol
#10 |
![]() Drives: 2017 2lt rs Join Date: May 2017
Small magnet works great
#11 |
Great suggestions - thanks!
#12 |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
Tim M,
Watched that "13th" Nürburgring visit video. Holy hell, i was scared just watching the video..., lol. Next business trip there, i must make time to visit that area. Thanks for sharing. ;-) |
#13 |
You and me both! Video doesn't do the track justice...drop me a line and I'll give you a ride!
#14 |
Drives: 19 Camaro SS 1LE, 03 Ford Lightning Join Date: Nov 2019
Just a quick question, but does boost really hurt or cause faster wear or premature failure to a valve spring? I would of thought boost would be irrelevant towards spring life on a motor with a stock cam, run stock RPM's?
Thread Tools | |
