12-26-2018, 04:54 PM | #1 |
Drives: 2017 ZL1 Join Date: May 2018
Do TSP Headers need rear O2 extensions?
Hey guys,
I am installing 1 7/8" TSP headers+x-pipe on my 2017 1LE and have used the 1 included O2 extension on the driver's front O2 sensor. My driver's rear O2 sensor (both connection ends are gray) are about 10" apart. Is a rear driver side O2 extention needed or am I missing something? I see no way to pull down the car side of the plug because it is on top of the transmission. Unfortunately TSP is closed this week... |
12-26-2018, 06:14 PM | #2 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Nope just unplug the connectors and put plugs in the x-pipe for the two rear O2 sensors. Your tuner can turn off the rear O2 sensors.
12-26-2018, 06:46 PM | #3 |
I wasn't going to tune until I did e85. I'm bone stock besides the headers.
12-26-2018, 07:07 PM | #4 |
Well in that case you have two options you can either plug the rear O2 bungs or call BBK I think they have a set of extensions out now for the rear O2s. If you just plug them you will have several codes pop up related to them not being connected. How long till you can tune your car? Adding headers on the stock tune is going to have you running lean so I wouldn't be doing any full throttle pulls and keep the rpms down.
12-27-2018, 11:19 AM | #5 |
Drives: 21 SS Join Date: Oct 2017
My tuner and shop added rear 02 after high flow cats, they said was best way in order to get tune right.
12-27-2018, 12:18 PM | #6 |
I don't have cats, so it looks like the best route is to tune out the rear o2's and add e85 while I'm getting a tune.
01-05-2019, 12:32 PM | #7 |
Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
Do you have any pictures of their xpipe? You are one of the first to post about installing it.
01-05-2019, 01:19 PM | #8 |
Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
Get a tune ASAP and dont race it. Headers on stock car runs a bit lean...
01-05-2019, 01:20 PM | #9 | |
You can just tune the rear 02s out in hp tuners software and problem solved. Seems like you were upsold for no reason... or the tuner isnt that experienced. |
01-05-2019, 05:44 PM | #10 | |
My tuner is 1 of the best and doubt they tried to upsell me for $8.
01-05-2019, 09:09 PM | #11 |
01-09-2019, 10:00 AM | #12 |
Drives: 2018 Redline Edition 2SS Join Date: Dec 2014
I think he was referring to the rear O2 sensors being plugged in for the "better" tune, not the cats.
2018 Redline Edition 2SS- A8, NPP, MRC, Recaro seats, ECS Novi 1500 tuned by EFX, cat deletes, Mighty Mouse Wild CC, GM STB, smoked ZL1 3rd brake light, Xpel XR Black 35% tint all around, Street Scene front splitter, C7 Carbon ZL1 side skirts Drake Muscle Car wicker bill, Adams Polishes Ceramic Coating
2010 Infiniti G37x Sedan for the DD. |
01-09-2019, 10:53 AM | #13 |
The rear o2's are for reading catalyst efficiency and have little to do with engine fueling. Most with headers or cat delete's turn them off in the ECU.
2016 NFG 1SS A8
01-14-2019, 11:54 AM | #14 |
Drives: 2017 SS 6sp Join Date: Jun 2014
