Old 09-14-2017, 02:37 PM   #29
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Here's my solutions. Header wrap, wire wrap and cut down TSP bolt
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 09-14-2017, 02:56 PM   #30
WhiteNight
WhiteNight's Avatar
Drives: MB 1SS
Originally Posted by Turbo_RORO View Post
wrong
100% correct
WhiteNight is offline   Reply With Quote
Old 10-10-2017, 03:28 PM   #31
TEEZYSS
Drives: 2016 CAMARO 2SS
Does the bolt rub in both the 1 7/8 and 2"?
2016 SS A8 STOCK 12.35@113.6 DA 1956
PRAY E85 TUNE,PRAY PORTED IM/TB,ROTOFAB DRY, DRAG PACK 11.33@121.8 DA 1248
PRAY PORTED MSD, 2" TSP LT's 11.38@122.4 DA 3664
GFORCE DRIVESHAFT,LME 174 T-STAT,ATI UDP up next...
TEEZYSS is offline   Reply With Quote
Old 10-11-2017, 03:40 AM   #32
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
on my 2017 the steering bolts were flush to the shaft.
Old 10-11-2017, 09:14 AM   #33
DapperDan
DapperDan's Avatar
Drives: 2017 1SS A8 Nightfall Gray
I would think If the bolt is rubbing on the 1/78" ,It would be even worse on the 2". Anyone with the 2" have any input on this,what about spark plugs hitting? back in the day Accel had a short plug for this issue ,also is there any extra issues installing the 2" ? Im thinking of going with these 2" but only want to buy headers once.
DapperDan is offline   Reply With Quote
Old 10-11-2017, 12:18 PM   #34
TEEZYSS
So the OP'S are 1 7/8?
Old 12-23-2017, 03:52 PM   #35
Slow_V8
Slow_V8
Slow_V8's Avatar
Drives: 16 white 2ss
I'm been trying install mine... but having some difficulties... been trying to fit it through top to bottom on a jack.... so far no luck so at this point I don't know if I should put it on a life and go bottom to top
2016 white 2ss, stainless work exhaust system and K/N CA
Slow_V8 is offline   Reply With Quote
Old 12-23-2017, 04:32 PM   #36
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
I went with Kooks, but I would say install is very similar. You will HAVE to go in from the bottom. I did it on Jack stands. In my garage.
1100 - 5/26
0000 - Cancelled - 7/5
Contacted Becky - 7/1
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 12-23-2017, 06:24 PM   #37
The_Coleman
Drives: 2017 NGM 1SS 1LE
And this is why I wish I had gotten the two piece RRs...
The_Coleman is offline   Reply With Quote
Old 12-23-2017, 06:27 PM   #38
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
What are two piece RRs?
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 12-23-2017, 07:59 PM   #39
The_Coleman
Heath
The Race Ramps. I goofed and didn’t notice when I ordered mine hat they were not the two piece setup. I was too lazy to deal with return shipping etc and figured “I will never really need to remove the ramp section.”. More than once, that feature would have very handy.
Old 12-23-2017, 09:11 PM   #40
KyBoy
KyBoy's Avatar
Drives: '17 2SS H50
I see now, duh. I do have them. They weren't high enough to do the headers. I had to go higher with jack stands. For smaller jobs, yes, they are handy.
Heath
1100 - 5/26
2000 - 7/5
3000 - 7/6
3000 - 7/11 TPW 8/1
3100 - 7/18 TPW 8/1
3300 - 7/20
3400 - 7/21
4300 - 8/3
5000 - 8/5
6000 - 8/13
Old 12-26-2017, 04:49 AM   #41
ocautomotive
Drives: 2017 ZL1 and 2018 SS 1LE
I have 2 inch tsp headers and can confirm the headers do rub on the shaft itself even after bolt replacement. Honestly gets kinda sketchy in high speed hard right turns as it feels like steering wheel gets stuck and you have to jerk it a bit to get it back. I will call TSP to see whats up.
ocautomotive is offline   Reply With Quote
Old 12-26-2017, 02:54 PM   #42
Kise
Kise's Avatar
Drives: 16' 2SS, 06' Silverado SS
Originally Posted by marknagy13 View Post
video it if you can!
do your kooks headers rub on the steering shaft? or any other issues?
Kise is offline   Reply With Quote
