Old 02-06-2024, 10:52 PM   #1
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
sub strap mount question.
I have the planted seat bracket and seat side mounts. What can I buy to attach the harness sub straps to. Will the brey krause sub strap mount fit with what I already have?
beworthy3 is offline   Reply With Quote
Old 02-07-2024, 07:16 AM   #2
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
The brey krause bar will only fit on their base.
Christian1LE is offline   Reply With Quote
Old 02-07-2024, 07:53 AM   #3
beworthy3
beworthy3's Avatar
are you aware of any other bars that will fit with a planted base? Or any other way to mount a sub strap bar?
Old 02-07-2024, 10:17 AM   #4
Christian1LE
Just looked up some pictures of their base. I think the easiest way to do it would be to buy/make a flat bar and mount it across the bottom of the planted bracket and then you can just mount the sub strap bar directly to that. Otherwise you will have to drill into the floor of the car or change to the BK base.
*You could technically make the BK bar work now that I look at it, you will just have to drill some holes in the planted base. You might even be able to use those existing holes, you will just need a backing planet on the other side to keep everything tight. (Attached a picture of my BK bar for you to come up with a plan). The only issue I see with the BK bar is that it will definitely be wider than the gap provided in the middle of the planted base, so you will either have to cut some of that out or mount the bar on top of the base which may make it too tall with respect to the seat.
Old 02-07-2024, 10:50 AM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
thats why i went with the brey krause setup they sold me the harness sub mount and all of that and it all bolted together super nice
Old 02-07-2024, 11:52 AM   #6
beworthy3
beworthy3's Avatar
So after some digging I found a cantrell motorsports sub belt mount that will sit right on top of the recaro slider. I thought I had bought everything I needed but theres always something else lol
Thanks for all the info
