06-01-2022, 12:49 PM | #1 | ||
Shadow Gray '19 ZLE M6
GoPro Tips / Discussion
I feel like I've finally dialed in my GoPro settings and camera position. I wanted to share with the community in the event it is helpful to anyone.
I'm using the Tackform Headrest Mount. There are a few different ones, but this is the one I went with: https://www.amazon.com/gp/product/B00XIB6SK4/ I use it mounted to the passenger headrest and it's adjusted to sit close to center between the two front seats. My GoPro is a Hero 9 and I have the Media Mod. There is still some wind noise with the Media Mod mic, but it picks up the supercharger whine nicely. As an alternative, I have a mic mounted in the trunk which sounds great and violent, but it misses out on the supercharger sounds. I'm going to play around with placement, maybe somewhere in the front wheelwell, engine bay or maybe even down in the interior passenger footwell to see what it picks up. Quick note: I was having overheating issues at 4K | 60 FPS, so I've dialed it back to 2.7K | 60 FPS. The settings I'm using are as follows: RES | FPS: 2.7K | 60 Lens: Linear HyperSmooth: Off Bit Rate: High Shutter: Auto EV Comp: -1.0 White Balance: Auto ISO Min: 100 ISO Max: 400 Sharpness: High Color: GoPro RAW Audio: Off Wind: Off Here is a track session from this past weekend at NJMP Thunderbolt: Open to other suggestions, but I'm pretty happy with the footage using these settings. Edit: As a comparison, here is the audio in a different session utilizing the external mic I have in the trunk:
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
06-01-2022, 01:06 PM | #2 |
i have a gopro hero 9 also and i forgot my settings but i use a rollbar mount and some lil screen covers to help with the glare/sun it works pretty well
06-01-2022, 01:34 PM | #3 |
I believe those are called ND filters. I haven't tried them, but I'm quite happy with the footage I'm getting with the above settings. The interior is a little dark in some scenes, but the view through the windshield is not washed out and is really clear (IMO). I can still see my steering inputs quite well and I like the angle of the footage. I assume your roll bar mount is in a similar location / similar view? Do you have any footage you can share using the ND filters?
06-01-2022, 01:41 PM | #4 |
there you go yup i already forgot lol and i have footage but still need to learn how to edit it and add the overlay since i dont have pdr im going to work on my footage from my last track day this week so ill post it up later
06-01-2022, 02:10 PM | #5 |
Drives: 2004 BMW 330CI, 2022 1SS 1LE Join Date: Dec 2021
I have a similar setup but I have my mic mounted above the exhaust outside of the trunk. I was thinking of putting it in the engine to see what it picks up but I haven't tried it yet.
06-02-2022, 06:17 PM | #6 |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
Your go pro settings are pretty much identical to mine. I also run 2.7k for resolution. I have my mic taped to my license plate when I want to record, sounds fantastic. I like your in car supercharger whine better than the trunk mic,sounds awesome.
I don't have PDR so I run track addict with an OBDII scanner to record telemetry. Here's an example of my setup. https://youtu.be/91HotxjnbG4 |
06-02-2022, 07:04 PM | #7 | |
06-06-2022, 12:32 AM | #8 |
Drives: 2SS 1LE Join Date: Oct 2011
The best interior shot I get is putting a harness on my px seat headrest and wrapping it with a crapload of blue tape. perspective is perfect. Doing a suction mount from the sunroof requires extensions to seem normal, but the headrest is a good spot.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-06-2022, 09:21 PM | #9 |
Drives: 22 ZL1 1LE A10 Join Date: Feb 2022
why turn hyper smooth off?
i use 2, one facing me, one on the road, mine look great at RES | FPS: 4k | 30 Lens: wide HyperSmooth: high Bit Rate: standard Shutter: Auto EV Comp: 0 White Balance: Auto ISO Min: 100 ISO Max: 1600 Sharpness: High Color: GoPro RAW Audio: Off Wind: auto |
06-06-2022, 09:28 PM | #10 | |
One other benefit I've noticed with turning HyperSmooth off is the footage looks "faster" and more violent (if that makes sense). However, the footage is more bouncy with HyperSmooth off. This is HyperSmooth ON This is HyperSmooth OFF
06-07-2022, 09:05 AM | #11 | |
Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
Here's a sample video from a stint at Summit Point in April.
I have GoPro 6 headrest mounted with a mic routed all the way into the trunk (above the exhaust)
#SAVETHEMANUALS
02-20-2023, 10:28 PM | #12 |
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
Your audio sounds really good. I’ve put my mic in 3 different spots in the trunk and I still get that helicopter noise with the windows down. Which mic did you use?
02-21-2023, 02:28 PM | #13 |
My gopro setup is an adapter for mic in. And a $15 mic clipped to the license plate.
That's all you need https://youtube.com/watch?v=t9kKPNvU_fY
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
02-21-2023, 02:32 PM | #14 | |
