Old 07-05-2018, 11:15 PM   #1
flaps100
flaps100's Avatar
Drives: 2017 Camaro 2.0 RS
Well this is not good.
Go out to my Camaro, wont start, details, 3900 miles 13 months old, ran perfect until now? Turbo 4, Auto.
When I went to start, it does all these snapping noises, says battery saver is on and then says battery low.
How can a battery go bad at only 3900 miles, I guess I am stuck until tomorrow when I can call the dealer, and no way to get to work either, bummer.
Flaps
flaps100 is offline   Reply With Quote
Old 07-05-2018, 11:31 PM   #2
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Loose terminal or ground... happened to me once.
ing for grip.
http://www.motorsportsne.com/
Old 07-05-2018, 11:36 PM   #3
flaps100
flaps100's Avatar
How to check
So do I just need to play with the negative and positive attached to the battery ? See if one is loose and then tighten it ?
Thanks for the info, Flaps
Old 07-05-2018, 11:46 PM   #4
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Don't believe it, do a search ...many batteries discharge/ go bad in the six GEN Camaro world… Nobody has a real good answer as to why.....
Old 07-05-2018, 11:55 PM   #5
flaps100
flaps100's Avatar
Checked it
Connections are tight, so I guess its not that, weird battery set up compared to what I am used to.
Guess the dealer can tow it tomorrow and hopefully figure it out.
Flaps
Old 07-06-2018, 12:00 AM   #6
twiget
Drives: '18 SS 1LE
The snapping sounds you heard are probably from arcing and sparking as something was shorting itself to ground. The battery terminals are as good a place to start as any. Make sure they are tight, the dust boots are in place and there's no exposed wiring. I'd also look for loose cabling under the hood, maybe a frayed cable with some exposed conductor, or melted insulation?
Make sure there are no cables near moving parts, or anything that gets hot, like the headers or your turbo. Also look for black scorch marks. If you find those, your probably going to find your failed cable near by.
Either way, your best bet is to get it towed to your dealer and not start it up until it's fixed. Good luck.
twiget is offline   Reply With Quote
Old 07-06-2018, 12:36 AM   #7
Mark114
Mark114's Avatar
Drives: 2016 2SS Convertible
Unfortunately even new car batteries occasionally fail without warning. A friend had one fail in their Camaro after 6 months. The dealer replaced it under warranty.
The clicking sounds you hear could be from the starter relay. Your battery has enough juice to energize the starter relay but not enough to start the car. If it is just the starter relay clicking then it isn't a dangerous condition like a short circuit and shouldn't damage the car.
Old 07-06-2018, 07:33 AM   #8
torqueaddict
Drives: Tesla M3 LR-AWD [Former 1SS owner]
90% probability it's a bad battery. Happens.
torqueaddict is offline   Reply With Quote
Old 07-06-2018, 07:38 AM   #9
Allez
Allez's Avatar
My Honda Accord had a bad battery that died within 2 weeks of my buying the car; the replacement battery died 2 years later.
Allez is offline   Reply With Quote
Old 07-06-2018, 07:49 AM   #10
Allez
Allez's Avatar
BTW, did you check to make sure you didn't accidentally leave something on?
Old 07-06-2018, 08:02 AM   #11
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
I will say this again. They will either find that the battery is not a problem or they will replace it. And then a year or two down the road it might happen again. Many of us have had this happen. There's something in the Camaro system that drains the battery through no fault of your own. I don't believe GM is giving us a good answer on this. I've gone through two batteries in my Camaro and they can find no fault found. I now have a quick disconnect switch on the battery so I can disconnect it if it's going to sit longer than two or three days…I'm actually going to get rid of the car pretty soon because of this problem.
Old 07-06-2018, 09:06 AM   #12
torqueaddict
Just came back from a 2 week vacation and it fired right up. We'll see in a year or so from now. The 1SS does have less gadgetry and / or maybe the 2018s are less prone?
Old 07-06-2018, 09:08 AM   #13
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
Mine fired up after being 13 weeks completely down with no disconnect. Six months later, it died after two days…...This has been going on for years, and no one has come up with a good answer yet.
Old 07-06-2018, 11:01 AM   #14
Lafourche1
Drives: 2019 CLA 450 Mercedes
If you have OnStar, just call them. They will give you a jump.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red
2014 Lincoln MKT EcoBoost (The Bus)
Lafourche1 is offline   Reply With Quote
