Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 07-14-2021, 07:56 PM   #29
Originally Posted by serper3 View Post
I already ordered it so it doesnt matter too much, but do you have a pic by any chance?
Did this cover the scratches left by the prior frame?
I am going to get some time today to hopefully finish polishing it. Hope that really helps with how the bumper looks, but either way, I am pretty sure the silicone frame will cover the scratches.
Yes, it does, see below (or, put another way, not see any of the scratches). No need to go overboard with that polishing—luckily my scratches are only in the clearcoat, hopefully yours aren't bad either
Magnuson TVS2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods
JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE replica wheels | BMR rear cradle lockout | JRE custom tune
Old 07-15-2021, 07:10 AM   #30
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1, 2019 SLC
When I got my car a few weeks ago, it only had 2 screws for the temp plate so when I mounted mine I drilled out the other 2 dimples. I actually ran a tap through the holes since had it handy, but really not needed for this.
For mounting screws, whatever you get just make sure they're stainless. I used black stainless in my case.
2018 Camaro ZL1 - Black
- OEM Options: Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- CAI Elite Carbon, SS1LE Wheels, SP TB, Eibach Pro, AeroForce Interceptor, Black GT4 Tow Hook
- ZL1 Emblems Painted NGM, Black "1" Inlay, 50% Headlight Armor, 5% Tint + 50% Windshield
- Carbon Fiber: Radio Trim, Shifter Trim, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2019 Superlite Coupe - SLC IR/8 - Grigio Telesto
- 525HP Crate LS3 & Graziano Transaxle
- 19"/20" Forgestar F14s, Full Carbon Interior, Brembos
infinitereality is offline   Reply With Quote
Old 07-15-2021, 09:32 AM   #31
Vigilante375
Drives: 2018 Camaro ZL1
I've just had the 2 screws the dealer put in for nearly 3 years and the license plate is angled out away from the bumper. Haven't had any issues with it scratching the bumper.
Old 07-15-2021, 11:16 AM   #32
serper3
Drives: 2018 Camaro ZL1 1LE
Awesome, thanks everyone!
serper3 is offline   Reply With Quote
Old 07-19-2021, 02:09 PM   #33
serper3
Update!!
Finished polishing the car finally. Saved the back bumper for last as it was the only area on the car that had issues, and it had two areas that needed help, besides the frame area. I think the before on these in real life was way worse than they look in the pictures. I am really happy with how this and the whole car turned out though!!
Going to be coating the car and then the new plate is going to go on with the silicone frame.
Name:  3 Plate After.jpg
Old 07-19-2021, 03:11 PM   #34
z28deuce
z28deuce's Avatar
Drives: 2021 Camaro ZL1
Looks good.
I'm adding this late but I also got a black silicone frame from Amazon, marked the locations and drilled 4 small pilot holes, then used the supplied self-tapping screws.
https://www.amazon.com/dp/B08MF38N9Q...ing=UTF8&psc=1
Different brand than the other link, but looks similar other than the included screw caps. Worked perfectly.
I had a nice (read expensive!) carbon fiber plate frame from my '16 SS I was planning to use, but on the '21 there's apparently less clearance between the body and the backup camera housing and I couldn't get the thicker carbon frame behind it and up high enough to work correctly.
Sent from my SM-A125U using Tapatalk
ZL1 Coupe, Wild Cherry Tintcoat, Black Metallic Center Stripe, A10, Red Knee Pads, Red Seatbelts, Nav. Ordered 12/12/2020, Built 1/14/2021, Arrived at Dealership 2/23/2021, Took Delivery 2/27/2021.
z28deuce is offline   Reply With Quote
Old 07-19-2021, 04:03 PM   #35
serper3
Originally Posted by z28deuce View Post
Looks good.
Thank you!
This was the route I was leaning toward as far as drilling small pilot holes first. Glad this worked out well and thanks for posting!
Yea my silicone frame looks like the one you have there, but its not a side slide type. I think I still prefer no frame, but the added protection against scratching I think is worth it, plus the small black border style frame is pretty unobtrusive and the black kinda matches the black trim.
Old 07-19-2021, 05:32 PM   #36
z28deuce
z28deuce's Avatar
You're welcome. That was my same reasoning, and it works perfectly and looks simple and clean.
Old 07-19-2021, 06:13 PM   #37
kropscamaro16
Drives: 2016 1ss camaro
lol never even looked at it or cared that much
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
