06-25-2023, 08:32 PM | #1 |
Drives: 22 ZL1 Join Date: May 2022
Lift Pad Weight distribution
We have all seen the horror videos of vehicles falling off two post lifts. Has anyone weighed your car at the front and back where you would have or install lift pads? If so, what is the difference?
2022 ZL1 M6
06-26-2023, 08:54 AM | #2 | |
https://youtu.be/x1S-p4yFtGo
'20 ZL1 1LE A10,
06-28-2023, 04:02 AM | #3 | |
Drives: 2018 Camaro SS Join Date: Jan 2021
Video doesn’t show where fronts go. Sent from my iPhone using Tapatalk |
06-28-2023, 07:34 AM | #4 |
Drives: 23 ZL1 6speed Join Date: Aug 2020
You put them on the lift points at the pinch welds. They should be seen by looking under the car.
“Straight roads are for fast cars, turns are for fast drivers.”
Gone but not forgotten: ‘17 Camaro 2SS Yellow 6speed |
06-28-2023, 07:40 AM | #5 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
Furthest forward, directly behind front wheel is the correct spot, not the one just behind that. Rear there is only one. Hope that helps!
