Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 10-10-2018, 09:52 PM   #1
mred2nice
mred2nice's Avatar
Drives: 2013 Camaro ZL1 & 1979 10.5 Camaro
2013 Driver Seat Upholstery Issue
Hello There
I have a permanent stain appearing issue with my driver's seat(part you sit on). I had it cleaned and it didn't come out. Further inspection, it appears it is burned/melted.
Is it even possible to have it re-upholstered? Or am I better off buying a new seat? If so, what is the going rate and do you have suggestions on where I can find one?
Thanks,
Ed
mred2nice is offline   Reply With Quote
Old 10-14-2018, 08:53 PM   #2
db59
Drives: 15 ZL1, 61 Vette, 32 Ford Roadster
You can just buy a new seat cover from GM, #23161545. Multiple sites online or from you local Chevy dealer. If you can't install it find a good upholstery shop near you to do it.
db59 is offline   Reply With Quote
Old 10-16-2018, 11:26 AM   #3
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
subd
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
Old 10-17-2018, 08:52 AM   #4
GONMAD510
Drives: 2013 ZL1 M6
This is good to know. The lower bolster is starting to look worn on mine from getting in and out of the car
Fast 850cc Injectors, ATI Balancer, 8.66 Lower Pulley, 2.55 Upper Pulley, Lingenfelter CAI, Kooks LT with cat delete pipes, Noweeds Exhaust Cutouts (extremely loud under full throttle), BTR Stage 3 Cam, BTR Platinum 660 Valve Spring Kit, TR7ix Iridium Spark Plugs, Lingenfelter Solid Isolator, 160 Degree Thermostat, Larger SC Coolant Reservoir with Hose Relocation Kit, BMR 1.25" Lowering Springs, MGW Short Throw Shifter, Racing Brake 2 piece rotors front and rear, Starkweather Performance Custom Dyno Tune on 91 Octane.
691.38 RWHP
630.35 RWTQ
GONMAD510 is offline   Reply With Quote
Old 10-22-2018, 07:28 PM   #5
mred2nice
mred2nice's Avatar
Thanks for the help on the part number.
Old 10-23-2018, 04:52 AM   #6
swampcritter
Drives: 2014 Camaro LS / 13 zl1
seat cover replacement
Originally Posted by mred2nice View Post
Hello There
Thanks,
Ed
I have to replace my drivers side also,for the same reason.I got an estimate of @50$ if I pull the seat.
swampcritter is offline   Reply With Quote
Old 10-23-2018, 06:13 AM   #7
VRZL113
VRZL113's Avatar
I just ordered a drivers side seat bottom cover for my ZL1. My seat has two tiny holes in the suede that were repaired by the original owner... Started bothering me, even though they aren't that noticeable. The correct part# per my vin# is 23161532 just an FYI for those ordering for their ZL1.
Old 11-06-2018, 06:49 AM   #8
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
These are per my VIN supplied request to gmpartsdirect. I got this back as far as front seat covers. NOTE: My car is a convertible. I do not know if the seats are different, but apparently the driver seat bottom is the same, so.....but you should verify to be sure.
23161566 Driver sear back cover; black in color (suede trim)
23161532 Driver seat cushion cover; black in color (suede trim)
23162177 Passenger seat back cover; black in color (suede trim)
23162138 Passenger seat cushion cover; black in color (suede trim)
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 11-09-2018, 08:50 PM   #9
1Willy1
Drives: corvette z06
how does the suede inserts age compared to leather?
Are they holding up well so far in most peoples case ?
1Willy1 is offline   Reply With Quote
Old 11-20-2018, 11:54 AM   #10
VRZL113
VRZL113's Avatar
I know I responded to this (not sure where my post went)....
The suede holds up great, as long as you maintain it. I use my Adam's cockpit brush on my seats, and steering wheel about once a week to prevent matting.
The steering wheel, and shift knob (with suede package), see extra wear from the abrasive contact with your skin on a daily basis. Keep that in mind.
