Old 12-18-2018, 12:27 PM   #1
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Total failure, something I am sure no BMW has ever suffered
My camaro's front blinker bulb on went out.
I wonder if this will require audi service position for simple bulb change ?
ing for grip.
http://www.motorsportsne.com/
Old 12-18-2018, 12:32 PM   #2
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Ouch, new bulbs in all positions.
Old 12-18-2018, 01:36 PM   #3
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Buy 'Murican
Old 12-18-2018, 02:27 PM   #4
ctrlz
I had an A4, and that's exactly how I remember that piece of crap. It suffered a remarkable string of failures once out of the warranty period. Spent many a day in service position. Easily worst car I've ever owned. I don't condemn all audi's, but I know poor engineering when I see it.
EDIT: In fairness, that photo shows something a bit beyond "service position," but still...
Old 12-18-2018, 06:52 PM   #5
Johnwiz
Johnwiz's Avatar
Drives: 2018 1SS 1LE
I love my '04 A4. It's got over 150,000 miles on it and has been very reliable as well as a blast to drive in the snow. Putting in the service position made it incredibly easy to do the timing belt. Although the AWD made doing the clutch a bit of a challenge.
Added a bigger turbo, injectors, a FMIC, exhaust and some bigger brakes, it makes a great daily driver.
Current - 2018 1SS 1LE, 2004 Audi A4 1.8T Ultrasport (DD)
Past - 1984 Camaro Z28 HO, 1988 Corvette Z51, 1993 Camaro Z28, 1999 30th Anniversary T/A, 2001 Corvette Z51
Johnwiz is offline   Reply With Quote
Old 12-18-2018, 07:00 PM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Looks like I'm short one functional 7440 bulb.
Long life or LED or regular ?
ing for grip.
Old 12-18-2018, 07:45 PM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Might as well upgrade to the cross drilled brakes lines while I am under there.
ing for grip.
Old 12-21-2018, 10:09 PM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Although 7440NA is supposed to fit the turn signal socket, it does so quite poorly, requiring what feels like enough force to pop the bulb.
Spec bulb for that location is WY21W.
The little feet/tabs that stick up on ends or the base are narrower than 7440 bulb.
I think ZLE needs rough service bulbs
ing for grip.
Old 12-21-2018, 10:15 PM   #9
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Confirmed:
Basically, jam it in there or dremel off area in pink - or just order the RIGHT bulbs.
ing for grip.
Old 12-22-2018, 05:35 AM   #10
redcoats1976
dont forget to change your blinker fluid while its apart..
redcoats1976 is online now   Reply With Quote
Old 12-22-2018, 05:49 AM   #11
SliChillax
SliChillax's Avatar
Drives: Camaro ZL1 A10, F-Type R, RR Sport
As a long time German car and BMW owner, I've had worse trust me.
SliChillax is offline   Reply With Quote
Old 12-22-2018, 09:17 AM   #12
Chris C 1SS 1LE
Chris C 1SS 1LE's Avatar
Drives: 2017 1LE
Had a 550 and wife an X3. Both with M package. Understand the "assume the position".
'17 Bright Yellow 1LE. PDR, STB, !CAGS
Borla 60606, 11925. Tony Mamo ported TB, ROTOFAB, !Sound Tube
Chris C 1SS 1LE is offline   Reply With Quote
