03-05-2021, 09:16 AM | #29 | |
Hot Camaro
Did a little more looking around and found an old Camaro brochure. It looks like the SS models offered the 20" wheels. The LT trims were equipped with 18" or 19" stock, but both had the 20" wheels as an option. That basically means that there should be zero issue with the wheels having the correct lug pattern and size along with correct wheel width and offset. On the older LT trims, the OEM tire size for 20" wheels was just a slight bit different in that the tread width and rim diameters were the same as a Gen6 SS, but sidewall was just a tad taller on the older cars. So, the wheel/tire setup you have should fit without an issue. But... the speedo and odometer may be off just a tad and read a little higher than actual. When you drive one 'measured mile' according to the odometer in the car based on the OEM tire size, you will actually travel 1 mile minus a couple hundred feet. At a speedometer reading of 60MPH, you'd actually be traveling around 58MPH (if my math is correct). |
03-05-2021, 09:32 AM | #30 | |
03-05-2021, 09:58 AM | #31 |
Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
Ah.. Nice.. Thx arpad_m
03-05-2021, 06:31 PM | #32 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
