10-03-2021, 05:25 PM | #1 |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
How to QUCIK FILL with 5 gallon jugs at the racetrack
Ok guys. I usually take with me 15 gallons of E85 in THREE fuel jugs with me to the track since most tracks DO NOT have E85. As most of you know it normally is a real pain in the ass to put the fuel in the car even with fuel funnels.
To solve that issue, I made a 1/2 inch diameter PVC fuel pipe extension that I directly attach to my fuel jug's MALE threaded end using a 3/4 inch female to female connector so that I can insert about 12 inches of the PVC pipe DIRECTLY into the filler neck. I can then empty the fuel jug fairly quickly without spilling any fuel. PICS are below are what I used. The KEY piece that makes this work without leaking is the SHARKBITE piece. It LOCKS in the PVC pipe into the fitting securely. The reason I DID NOT use all PVC material is I could find the correct sizes needed. Using this you can vent the jug and fill it at fill flow without stopping.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 10-03-2021 at 05:37 PM. |
10-03-2021, 05:44 PM | #2 |
Drives: 2020 SS 1LE Join Date: Aug 2020
My initial thought was - why do you need to refill quickly as if you’re in a race.
Then I remembered how long it takes to empty 5 gallons into any car. Even if you have time, it sucks to hold the can that long while trying to not spill anything. What’s also cool is that it seems you could insert the pvc pipe fully before even tilting the can making spills almost impossible. Nice work! Saving for future implementation. |
10-03-2021, 07:28 PM | #3 | |
Your comment regarding having the jug on the ground with the fill extension being in place is EXACTLY how I wanted it. see pic below.\\
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 10-03-2021 at 07:49 PM. |
10-03-2021, 09:32 PM | #4 |
use the GM little black funnel thingy which comes with the car...seems ridiculous but it works best for me. Your trick is nice too as it will release all of the flaps which typical funnels do not.
10-04-2021, 01:55 AM | #5 | |
10-04-2021, 02:13 AM | #6 | |
It takes about 90 seconds to empty the 5 gallon jug into the car. The PVC extension tube of 1/2 an inch diameter prevents it from flowing faster. HOWEVER thats ALOT faster than using a funnel and sloshing the fuel back and forth thru it into the tank. Since the largest diameter PVC that you can use on the extension is 1/2 inch, the filler neck in our cars is the restriction really. The filler tube that comes directly off the Jug is 3/4 an inch. I guess GM did that as an anti Theft device regarding fuel (baffled reduced diameter filler neck). If you ever tried to siphon fuel out of you car for any reason it is next to impossible. I am sure also GM also did that due to wanting to keep fuel vapors from escaping into the atmosphere from your fuel tank due to an EPA restriction.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 10-05-2021 at 06:52 PM. |
10-09-2021, 09:47 PM | #7 | |
Drives: audi R8; ss 1le; F250 Join Date: Mar 2021
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
10-10-2021, 11:15 AM | #8 | |
Yeah isnt that a bitch about those jugs leaking at times??? Sometimes no matter how tight you screw on the lid it leaks for no damn reason at all. I myself have one like that now that I NEVER use for that reason. THANKS!!! If I already didnt have about ten of the old style jugs myself I would buy the new one and try it myself!!
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
10-10-2021, 02:53 PM | #9 | |
Drives: 2017 Arctic Blue Metallic A8 SS Join Date: Mar 2017
2017 SS Arctic Blue Metallic A8 GM big brake kit SG3 Lowering & FE4 sway Bar Kits
10-10-2021, 06:37 PM | #10 |
Well WTH, make your own.
10-11-2021, 08:36 PM | #11 |
Drives: 2018 ZL1 1LE Join Date: May 2020
I have the VP racing 5gal jugs with this long plastic pipe nipple on them and have never had an issue getting fuel in. It empties the can in about 2 min or so.
10-12-2021, 10:22 AM | #12 | |
haha i have the same one and they wouldnt ship it to me in cali had to call them and order direct my gf laughed at me for ordering one told me she could have made me one at home depot for $5
11-19-2021, 06:46 PM | #13 |
Welp, I assembled something almost identical… instead of 1/2” pex, I used 3/4” pex tubing. Snug fit but not tight. The clear tubing on my jug wasn’t long enough so I had to use a longer piece of pex tubing.
I’m glad to report there wasn’t any spillage and 5 gallons only took 65-70 seconds. For reference, the pump at the gas station dispensed 5 gallons in 52 seconds. Close pace! We’re going to use this rig for our Lemons race in 2 weeks! Thanks OP |
