06-08-2016, 03:15 PM | #3473 | |
General Motors Aficionado
Drives: 2023 GMC Canyon, 2020 Colorado Join Date: Aug 2008
And in the end, they have a point. It is a marketing stunt for sure. The problem is, it's a marketing stunt that could very well happen in the real world, maybe not cinder blocks dropped from 5 feet into the truck bed, but the tool box being thrown in is. I'm curious if it actually has happened in real life...
2023 GMC Canyon Elevation 2020 Chevrolet Colorado W/T Extended Cab (State-issued) |
06-08-2016, 03:48 PM | #3474 | |
Drives: Current Camaro-less Join Date: Jul 2014
06-08-2016, 03:58 PM | #3475 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
I could see GM doing steel in the bed that's welded to aluminum either higher up on the sides of the bed or to the rear 3/4 panels.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
06-08-2016, 04:06 PM | #3476 | |
Yee-aay-ee!
Drives: 2015 2SS/RS CV CE Join Date: Nov 2015
06-08-2016, 04:58 PM | #3477 |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
Aluminum is definitely the future for GM trucks and they will need the spin team in full effect once they roll out aluminum GM trucks. However, Ford has been running the "military grade" bullshit for their aluminum, trying to make it sound like its some super strong alloy. Military grade is meaningless when you don't take into account what the military was using the aluminum for. The M16 uses aluminum receivers, but the parts that take all the stress are still steel.
I pray to whatever deity is listening that GM uses a steel bed, for at least the floor and walls.
06-08-2016, 05:45 PM | #3478 | |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
The Bird is the word! |
06-08-2016, 06:11 PM | #3479 |
Tanks typically don't, but vehicles that aren't expected to stop HEAT (high explosive anti-tank) or depleted uranium sabot penetrators (IE main battle tanks and some heavy IFV's) do use thick aluminum plates for armor. Example being the latest up-armor kits for hummers use half-inch high strength aluminum. it's also used for some structural elements in ships such as frigates and destroyers where weight and top-heavy characteristics are of concern.
06-08-2016, 09:11 PM | #3480 |
The M551 Sheridan used aluminum armor, but it's hardly a tank. The vehicle they showed looked like an M2/3 Bradley, which doesn't use aluminum armor. It uses layered composite armor. Their may be aluminum in it but it's not entirely aluminum.
06-08-2016, 10:18 PM | #3481 | |
Moderator.ca
Shooting missiles from the gun on the other hand ... ? Why not just stick a couple launchers on the outside of the turret, similar to what ended up happening on the Bradley? Seems like that would have been a much better solution to give the tank some anti-armour punch. Anyway, it was still a tank. A light tank, sure. But a tank none the less. It just put a lot more emphasis on the mobility part of the tank design triangle (firepower, protection, and mobility). But thats just the nature of a light tank.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
06-10-2016, 12:53 PM | #3482 |
06-10-2016, 06:52 PM | #3483 |
Express/Savana cutaway production outsourced to Navistar to free up production capacity for midsize trucks at Wentzville.
06-13-2016, 10:40 AM | #3484 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Any word on any performance version of the new Cruze?
06-13-2016, 01:06 PM | #3485 |
Nothing solid.
06-13-2016, 02:11 PM | #3486 |
Drives: F350 Join Date: Jun 2015
Tags |
fenwickhockey65, gm questions, questions |
