08-02-2020, 01:12 PM | #29 | |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
I dropped the cradle, but kept it under the car. This way I didn't have to disconnect the diff cooling lines. Only unclip from the tunnel and let droop.
It can be done on a Quick Jack, a little finagaling is required to get the front braces torqued up though. I did loosen the front brace bolts before lifting the car. Someone asked about the alignment bolts: they are not touched during the bushing swap, they are furnished only because an alignment should be done after. I used a two arm gear puller to get the rubber bushings out. No heat was required. super simple Video here:
08-02-2020, 03:18 PM | #30 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
Install isn't bad. I did a track day right after I installed mine and thought it was the best handling mod to date. Went on a tour of local vineyards with the wife the next weekend and almost changed my mind. The solid bushings transmit and amplify the drivetrain lash and make Sunday drives a good bit less enjoyable. I'm on the fence about swapping mine for some poly bushings or maybe even going back stock with the lockout kit. I am a6 which exacerbates the problem, I'm sure.
Baby Blue
08-02-2020, 03:39 PM | #31 |
Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I’m thinking about the lock out kit. I don’t want to drop the whole cradle and don’t want to have to torch out the old bushings. Also don’t want to have amplified drivetrain noises afterwards.
08-02-2020, 04:01 PM | #32 | |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
08-02-2020, 05:08 PM | #33 |
I have the BMR lockout kit, and it didn't worsen the ride or NVH, at least not to a level I (or my wife) can perceive, so that's unlikely to be an issue
08-03-2020, 10:49 AM | #34 |
Drives: 2018 ZL-1 Join Date: Jan 2018
I'm very happy with the lockout kit and the upgraded control arms, etc. BMR warns people about the increased NVH of the solid bushings. For a street car, the lockout kit is the way to go.
08-03-2020, 06:31 PM | #35 |
So the place i ordered the bushing said they might have them at the end of August sounds to me like BS. So I canceled my order and now I have to find someone that has them on a shelf. I know they are hard to find,if i can't find them I guess ill go with the BMR lock out kit.
08-03-2020, 07:39 PM | #36 | |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
08-03-2020, 09:35 PM | #37 | |
TWG1
Drives: 2019 Camaro ZLE Join Date: Nov 2019
2019 ZLE M6
2019 ZL1 A10 (Sold) 1967 Jaguar XKE Series 1 Roadster 2021 F150 Powerboost (on order) |
08-03-2020, 09:48 PM | #38 |
That is probably the why I'm going the good thing about the GMPP is it comes with all new bolts and its cheaper.
08-03-2020, 09:53 PM | #39 | |
My car is basically identical to a 1LE except for the ediff. It's possible that the clunking is not as pronounced with the ediff.
Baby Blue
08-03-2020, 10:02 PM | #40 |
+1 on the lockout kit.
08-04-2020, 12:12 PM | #41 | |
Interesting on the clunking. I have no such clunk stock or afterwards.
Current:
08-05-2020, 03:58 PM | #42 |
Drives: 2012 Porsche 911 Turbo S Join Date: Jan 2017
Mine came in this week. now i just need to find some time to do it.
IG: 2fast2nick
-- Current -- 2012 Porsche Turbo S - PDK - Basalt Black Metallic -- Past -- 2017 Camaro ZL1 Coupe - Red Hot - A10, PDR - HRE P101 2015 Mustang GT PP - Whipple Supercharger |
