08-01-2020, 08:40 AM | #1 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
355/30R19 Kumho fitment report
Thought I would at least throw some pictures up of the fitment in the rear, I have been running these Kumos pretty hard now at autocross and track days, the wiring harness has been re located and the fender liner pinned back.
You can see on the driver side fender liner has still rub through slightly and has touched the body a few times but nothing hard enough to damage the tire and on both sides you can see the tire under full compression will touch the inside lip of the fender, I have added some clear paint protection film on the edge of the fender to help with some of the rubbing, but after all it is just a track beater. The car is setting at about -2.2* of rear camber to help tuck the tire into the fender under compression.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
