07-28-2020, 10:41 AM | #29 |
Drives: 2018 ZLE Join Date: Feb 2018
I would buy something a year old and get the SS 1LE. Nothing against the V6 cars as they are probably faster then my C5 corvette but there is just something about that sound and feel of a V8 that gets me. Same thing with the Porsche, I know they are incredible cars but just not for me.
07-28-2020, 10:58 AM | #30 | ||
Drives: Chevrolet SS 1LE Join Date: Oct 2019
My position is that just in terms of the OE tires alone, the 1LE is going to let him go straight to the track event without having to purchase a new set of performance tires. It's going to run cooler and the brakes will be much more appropriate for this use. For this OP's intended use, it's a way more practical purchase. This is different than you or me: we both probably enter in a dozen or more events each year and the classing is important for us. And you're in a class that allows any wheels/tires you can fit on the car, along with eleventy-billion other mods (I've been there too!). This OP has a different mindset than we do for his car, I believe. PS - Your point about the availability of used V6 1LEs is valid. I've been assuming the OP is planning to purchase new, which renders that point moot. But if he's really looking at used Camaros, then yes it's going to be a lot harder to find a V6 or 2.0T with the 1LE package.
Matt Miller
2020 SS 1LE |
07-28-2020, 11:27 AM | #31 | |
Drives: 2018 Camaro SS1 1LE Join Date: Feb 2017
The 1LE has a better suspension, as has been discussed here, which is going to give you faster times, it also has better tires AND wheels, which are also going to improve times. I don't believe anybody has mentioned the eLSD. That makes a bigger difference than you might think. Much more nimble through the corners. Better brakes means better times, and all those coolers mean you can not only run faster, you can do it much longer. All those factors are more than just 'nice to have' when tracking. MT had the figure 8 for a 2018 SS 1LE at 22.9 and for a 2016 SS at 24.1. From my perspective, 1.2 seconds is a big difference. |
07-28-2020, 11:37 AM | #32 | |
Matt Miller
2020 SS 1LE |
07-28-2020, 11:45 AM | #33 | |
07-28-2020, 11:59 AM | #34 | |
Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
For 1-2 track days a year, it's all certainly nice to have especially if you're going on 90* days, but you can still track the car without it. I know someone who has tracked their base 2.0T with just pads and fluid, and the only issue they mentioned was the brakes were pretty hot towards the end of the sessions. If money is a non-issue, then why not get it. If, like most people, it plays some consideration, then you have to decide if it's worth it for yourself. Don't take away track time from yourself because you stretched into the payments for the 1LE. Go out and test drive as many combinations as possible. Maybe after driving an LT1 you decide you have to have the V8, they're going to be pretty close in price.
07-28-2020, 12:19 PM | #35 |
Rayvan
Drives: 2018 1SS1LE, Silver Ice Metallic Join Date: Dec 2018
I'd get the V6 1LE. Wouldn't it be great to say that you can beat an 800HP Hellcat on a road coarse?
07-28-2020, 12:23 PM | #36 | |
Drives: '21 V6 1LE Join Date: Jul 2020
I was originally looking for used, but it's accurate that the V6 1LE is very hard to find, and honestly not much cheaper than new in the grand scheme of things. So I'd likely go the new route. Money is a concern but not too much. One dealer warned me that the 1LE comes from the factory with negative camber and will quickly wear out the insides of the tires. Is this true? If so obviously I can get it adjusted, but just something I'd like to know. I do think the 1LE is special enough that it offsets some of the stigma around a V6. Honestly it sounds fantastic to me, even though a V8 sounds better. I just tested a Mustang Ecoboost, and the sound and not-so-linear power delivery makes me think the V6 is my play here. Thank you all again for all of your insights! |
07-28-2020, 12:25 PM | #37 |
Holy shitballs, I didn't realize the Hellcat was that bad on a road coarse. I looked it up in lightning lap, and the Hellcat is only a half-second faster on VIR Grand Course, which has some pretty long straights.
07-28-2020, 12:33 PM | #38 |
Haha that's nuts! More importantly, I could use more than 10% of the performance on the street without going to jail.
07-28-2020, 12:37 PM | #39 | |
I had a long debate on whether I wanted the 2.0T or V6. Ultimately the 2.0T won for it's tunability (is that a word?), but the V6 sounds pretty good, and NA power is always nice.
07-28-2020, 12:41 PM | #40 | |
Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
Not sure about the factory negative camber for the v6 1le... the v8 is ~1.5degrees. I've had my car for ~14k miles with about 5k miles at -2.5, and the rest -1.5. I had no weird tire wear. My previous car, a bmw 1 series had -2deg camber for ~60k miles. The tires definitely wear more on the inside, but it's gradual wear across the face. I don't think it significantly affected tire wear. All of these cases i ran zero toe in front, i think toe affects wear more, especially with negative camber. |
07-28-2020, 12:43 PM | #41 |
That's a big reason I left the modern V8s. After getting a 41 over ticket at the end of an on-ramp, I decided they're too fast to be truly enjoyed on the street. If the 2.0T is good enough for Randy Pobst, it's good enough for me.
07-28-2020, 12:44 PM | #42 |
Cool thanks guys. The car would get about 13k miles per year commuting, so I'll definitely look into the camber specs if I purchase and then go from there.
I know the 4 can easily be made to be quicker than the 6 but I'm not going to be doing any tuning. |
