07-21-2020, 09:51 PM | #1 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Car won't connect to WiFi
Greetings, all.
2017 1SS. I turned off WiFi in the car years ago, but recently thought I would re-enable to see if there are any updates OTA. Now, it sees my network, but fails every time it tries to connect. I'm using WPA2. Signal strength is good. I also tried using a Hotspot on my iPhone and it connects to that, but then says there is no network available. Any ideas on further troubleshooting? TIA.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
07-22-2020, 12:28 AM | #2 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
That's not how the car's wifi works.
The car is the access point (hotspot). It gets to the internet thru it's cellular connection that you have to subscribe to and is part of the onstar module. It wont utilize your phone's internet connection in order to provide access to other devices or anything like that. This is a convenience feature so various cell phones can avoid having to use their own cell modules to access the internet for the supposedly stronger car cell radio (though they also get to monitor everything your devices do and sell that info to advertisers and what other related business partners ...which you sign away the rights to when you subscribe). It has nothing to do with things like android auto or any music streaming where the data is coming from your cell phone ....that stuff streams from your phone via cell radio on your phone (unless you're connected via wifi, in which case if your car isn't subscribed ...you wont get any internet access while connected to the wifi). |
07-22-2020, 07:41 AM | #3 | |
Hot Camaro
In the Settings menu, you have both Wi-Fi Hotspot and Wi-Fi Networks. From Wi-Fi Networks, you choose the network you want to connect to and enter the password for it if required. At that point, you should be prompted to agree to the ridiculous terms and privacy statements and should then be able to be "on your way" using the Wi-Fi network you just connected to. See attached photos. With regard to software updates, I don't believe that there is any requirement for OnStar to be active. My car had the generic one month service that I let lapse because I -never- use any of their features and I was able to check for updates this morning manually (it found none). |
07-22-2020, 07:46 AM | #4 | |
Hot Camaro
For the software updates, just go down to that section of the settings and check for updates. Make sure the car is outside in an area where there's a clear view of the sky AND you should get AT&T cell signal (that's the carrier network that these systems are tied to). As an aside... There used to be a way to get your car added to a multi-device plan from AT&T by providing them with the eSIM of the car, but I don't know if this is possible with these units. I had considered doing this for my 2015 Silverado when I realized that I would be paying more money to use the same data from my phone and never went through with it. |
07-22-2020, 10:24 AM | #5 | |
indeed, the 2016 doesn't do any of that wifi network connection stuff, doesn't have the option setting or anything. It is strictly a hotspot/access point and gets it's internet connection from the 4g cell radio in the onstar module. I figured the 2017 was in the same boat (which is what the op has) ...but it would seem not. |
07-22-2020, 10:33 AM | #6 | |
Hot Camaro
07-29-2021, 04:53 PM | #7 |
Drives: Camaro 2ss 2018 Join Date: Jun 2021
I find a way to fix that problem
Try to go to setting than to factory reset or like that click on clear data more than two time and you will get a new massage that say you need to turn off your auto and open close the door and wait one minute . This will full reset your auto data
