Old 07-20-2020, 09:54 AM   #15
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
I recommend the SS brake deflectors to everyone who is tracking a Camaro. There is no good reason not to run them, but most 1LE, ZL1, and ZLE guys just say "our cars don't need them"...
The GT ducts should be better, but they quit producing them because of the wear thru problems and they never provided data vs the SS deflectors to show how much more effective they were. Cost wise, the SS deflectors clearly win.
Old 07-20-2020, 10:30 AM   #16
davidwarren
Drives: 2019 SS 1LE
Originally Posted by carguy55 View Post
I had the GT ducts and switched to these. Kept wearing thru the hose but you may have better luck.
https://www.gmpartsgiant.com/parts/g...-84145204.html
Is this both sides? I don’t understand why this isnt included with the 1le if it works better...
davidwarren is offline   Reply With Quote
Old 07-20-2020, 10:39 AM   #17
TheRealJA105
Drives: 2013 C6Z06
Because the deflectors are technically for cooling the 4 piston fronts on the SS and GM didn't deem them necessary for the larger 6 piston brakes on the 1LE or ZL1s. I have the 6 pistons and run them 24/7 on my car.
Old 07-20-2020, 11:46 AM   #18
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
The base SS doesn't have the brake ducts, so the larger / lower control arm deflectors plus the smaller heat shields were "junk in the trunk" to be used only for track use. I'm sure that's because of how low they are and they can kick water and debris towards the front brake back sides.
However, many of us leave have Camaros that came with front OEM brake ducts, replaced the smaller control arm deflectors with the larger / lower ones, and leave them on 24/7 as TheRealJA105 said.
RUQWIKR is offline   Reply With Quote
Old 07-20-2020, 01:41 PM   #19
MatthewAMEL
MatthewAMEL's Avatar
Drives: 2023 CT5 Blackwing
I dropped Velossa Tech a message asking if they would be interested in making a cooling solution for us. I used their brake cooling on my FoST and it was great.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
Old 07-20-2020, 02:02 PM   #20
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Do the SS brake cooler fins come as a pair?
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 07-20-2020, 08:46 PM   #21
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
Yes it's a pair of the deflectors and the smaller splash shields.
https://www.gmpartsdirect.com/oem-pa...ector-84433357
Old 07-21-2020, 07:33 AM   #22
TheRealJA105
Drives: 2013 C6Z06
All SS coupes have the same brake ducts and the same stock control arm deflectors as the 1LE, ZL1, and ZLE. They just came with the junk in the trunk to cool the smaller 4 piston fronts on track.
LT1s do not have the brake ducts or the auxiliary radiators. I think the same for SS convertibles also, but I'm not sure on that.
Old 07-21-2020, 08:37 AM   #23
driven2exceSS
driven2exceSS's Avatar
Drives: 2016 2SS BLK A8 Vert
You are correct, I had to install/cut-in the ducts and buy the deflectors, and do not have the additional aux radiators in the wheel wells ...FWIW I too have since left the larger / lower control arm deflectors plus the smaller heat shields on 24/7.
driven2exceSS is offline   Reply With Quote
Old 07-21-2020, 11:07 AM   #24
carguy55
carguy55's Avatar
However only the ZL1 and ZLE come stock with the small splash guard /heat shield that comes in the kit.
Old 07-21-2020, 12:17 PM   #25
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
I said "base" meaning the LT1. Correct also on the convertible SS's (and LT1's) don't come with V18 aux coolers / radiators nor the brake ducts from the lower grille area to the wheelhouse liners.
Old 07-30-2020, 03:33 PM   #26
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Can anyone confirm or deny any clearance issues running the SS brake deflectors on a ZLE?
Old 07-30-2020, 03:53 PM   #27
m3bs
m3bs's Avatar
Drives: '19 ZLE, S54 E36M3
Hard to tell from those pics, but it looks like those rotors had enough wear that I would have replaced them long ago, even ignoring the heat checking. How many track days on them? What pads?
m3bs is offline   Reply With Quote
Old 07-30-2020, 05:34 PM   #28
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
I just got my SS deflectors today, so hopefully I will get them thrown on today or tomorrow and take a few pictures.
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap
ICTsccaCamaro is offline   Reply With Quote
