Old 06-09-2020, 08:25 PM   #1
JoeCamaro444
JoeCamaro444's Avatar
Drives: 2018 2SS M6 Hot Wheels Camaro
Under the SS hood question
As a car guy, I find myself feeling weird asking this question, but here goes:
Is there no Power Steering reservoir visible under the hood? Is it a closed, dealer service only, system, as the transmission fluid is supposed to be?
I took inventory under the hood today, after having the A8 Shudder issue addressed with the latest updated fluid flush. I obviously spotted the crankcase oil fill lid, the oil dipstick, the engine coolant reservoir, brake booster and brake fluid reservoir, battery, fuses, washer fluid reservoir, etc...I noticed that there was no transmission dipstick, which led me to further reading of the owner’s manual, where it stated that “you do not need to check this system...it is to be serviced by the dealer, and unless a leak develops, there is no need for anything else.” I read that the engine coolant is similar in that other than if you notice the fluid in the reservoir low, no need to worry there either. Craziness! lol Lastly, I find no mention of the Power Steering system, fluid or reservoir in the manual. I’m guessing this is a similar system in that GM didn’t want us touching or seeing that either! 🤷🏻
Looking for any useful info from someone that knows more about these cars than me. I know a fair amount, but I’m still learning, and welcome more knowledge on it. Also, someone please correct me if I’m wrong with any of the above deductions.
2018 2SS M6 Hot Wheels Camaro loaded (Moonroof, Magnetic Ride Control, NPP, etc…)
Previous cars:
2017 1SS Nightfall Gray Metallic w/A8 and NPP
1988 IROC-Z (tons of mods), 1995 Z28, 1998 Z28, 2006 GTO, 2010 Camaro 1SS, 2015 Subaru STI, a couple Acuras and multiple Jeeps.
JoeCamaro444 is offline   Reply With Quote
Old 06-09-2020, 08:47 PM   #2
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
I don't know for sure, but perhaps the power steering is an electric system???
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires
Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph...
Old 06-09-2020, 08:54 PM   #3
JeffFox
Drives: 2018 2SS Coupe A8
Electronic power steering
No fluid
JeffFox is offline   Reply With Quote
Old 06-09-2020, 09:45 PM   #4
JoeCamaro444
Mind=blown
Thank you, both, for your replies. I was able to find answers in the owner’s manual for the closed transmission system, and the “barely needs service” engine coolant system...but I never thought of that for the power steering.
Thank you 👍🏻
Previous cars:
Old 06-10-2020, 03:29 AM   #5
cdrptrks
cdrptrks's Avatar
The electronic power steering is what allows the 3 different selectable steering modes. I prefer touring steering mode personally. I still prefer hydraulic power steering but this car's electronic power steering has a much better feel than most cars I have driven.
Old 06-10-2020, 06:35 AM   #6
VinnAY
Drives: 18 1SS/1LE
The electric in the Camaro is better than my 15 Mustang, that thing had a real dead spot in it if you sawed the wheel back and forth.
Old 06-10-2020, 11:00 PM   #7
JoeCamaro444
It is definitely an outstanding electric setup. I think it feels very natural, and once I read the replies in here it made so much sense. It just went right past me initially.
Previous cars:
Old 06-21-2020, 07:36 PM   #8
Petrol Head
Drives: Fast if no one's looking
Electric power steering has been around for about 15 years. It used to be awful and people yearned for hydraulics again, but they’ve gotten much better now. Hey less fluids to change, less to leak, one less pulley taking hp from your engine. What’s not to like?
Petrol Head is offline   Reply With Quote
Old 07-01-2020, 01:22 AM   #9
JoeCamaro444
In full agreement. I’m thrilled by the feel and response of the system, plus less maintenance. It’s a win, win.
Previous cars:
Old 07-21-2020, 03:19 PM   #10
NewCamaroOrder
Drives: 2017 Camaro 2SS Nightfall Gray 1LE
Simply for clarity, you found your battery in the right rear fender and not under the hood? I'm sure you did but was compelled to ask.
NewCamaroOrder is offline   Reply With Quote
Old 07-21-2020, 04:16 PM   #11
Petrol Head
If you remember your old cars with hydraulic pumps, and you turned your wheel while at a complete stop, you might have noticed your engine RPM drop briefly before coming back up to idle while you hold pressure on the steering wheel. That tells you how much power the hydraulic power steering pump actually consumed from the engine. Do that with the Camaro and zero RPM drop.
Old 07-23-2020, 02:39 PM   #12
JoeCamaro444
Thank you for checking, and I did. I should have written under hood battery terminals. I have peeked at the battery location in the past, just to see how much of a pain it would be to replace. lol
Previous cars:
Old 07-23-2020, 02:43 PM   #13
JoeCamaro444
Very good point. As time and technology advance, I just have to keep the tried and true methods in mind. Some cars were worse than others with that power zap, when you had the wheel at full turn. I remember some that used to feel like they were going to stall out, before I knew what was happening. 👍🏻
Previous cars:
Old 07-23-2020, 02:57 PM   #14
UnknownJinX
UnknownJinX's Avatar
Drives: 19 Chevrolet Camaro 2SS 1LE Shock
Yeah, a lot of modern cars use electric power steering to reduce parasitic loss from pumping hydraulic fluid(so less emission, better gas mileage, etc.) and to enable multiple steering modes.
And honestly, the hydraulic ones are a bit of a pain to maintain. When I bought my first car, it came with burnt fluid and the steering wheel would not return on its own after finishing a turn. I ended up having to flush it many, many times before it became clear. Not fun, and Honda power steering fluid smells awful.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock
GM Performance Intake and that's it, because driver mods before car mods
Past:
2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold)
2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled)
UnknownJinX is offline   Reply With Quote
