05-07-2020, 06:37 PM | #1 |
Drives: 2018 Camaro 2SS Join Date: Feb 2019
Reading Ethanol Content
I just got a flex fuel tune for me SS. I want to get a gauge that will read the ethanol content so I know how much e85 to 91 octane mixture I should use. Anybody have any insight on which I should get?
05-07-2020, 07:04 PM | #2 |
Drives: 2019 Camaro 2SS Join Date: Jan 2019
i use my hp tuners to check mine
05-07-2020, 07:05 PM | #3 |
For me I like the Banks iDash 1.8 SuperGauge. It will show ethanol and so much more.
https://www.bankspowerproducts.com/B...ge-p/66560.htm HP Tuners works too, I just didn’t want to tote the tablet around anymore
05-07-2020, 07:57 PM | #4 |
I just looked at that banks one and it looks super nice. Other people said that banks didn’t read e content? Maybe yours is more updated? It seams like it’s a good bed being it plugs right into your obdII
Also yes hp is great and ngauges but i don’t necessarily wanna spend hecka money just to read e lol |
05-07-2020, 08:08 PM | #5 |
Yeah I believe it was G2K that actually had an earlier version and he flashed it to get the “E” to read. I ordered straight from Banks and also downloaded the firmware. When going through the process, it mentioned the update was already installed. Overwrite?? No need.
Now, out of the box I went to setup the gauge layout and no “E”. Come on, it stated it was the latest version. I recall seeing the vehicle types in the setup menu and after selecting GM the “E” worked fine. If you’re comfortable that is the gauge you want, I can say that if you get it from Banks you should be good to go.
05-09-2020, 12:43 AM | #6 |
why are you mixing e85 and 91? the SS can handle E85.
07-29-2020, 08:23 PM | #7 |
Drives: 2016 2SS 6MT Join Date: Apr 2020
Where in the banks idash do you find ethanol content? For the life of me I couldn't find it. I have the latest firmware
07-29-2020, 08:34 PM | #8 |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
So im going to be running the i-dash also but I called Banks and said that that there system doesn't have that it works with 2020 only with a 2018. Which obviously its the same so tbey sent me a text gauge so tbey can update there system. So most likely it will work with the new firmware.
07-29-2020, 09:07 PM | #9 | |
https://www.camaro6.com/forums/showt...2#post10805302
07-29-2020, 09:12 PM | #10 |
Drives: 2016 F150 Join Date: May 2019
I used the torque app on my phone and a Bluetooth obd2 adapter only cost $20
07-30-2020, 12:47 AM | #11 |
Drives: like an old lady Join Date: Jun 2012
what's the question? use as much e85 as you can.
07-30-2020, 05:53 AM | #12 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I use fuel-it, it's a bluetooth adapter that hooks up to your fuel line and sends the info to your phone. I didn't want a gauge in my car for a more stock appearance.
07-30-2020, 06:17 AM | #13 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
This^
Baby Blue
07-30-2020, 07:48 AM | #14 |
Torque Pro app with BT OBD2 adapter as others have mentioned.
2016 NFG 1SS A8
