TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6)
Old 04-22-2019, 06:24 PM   #1
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Eaton truetrac 1 wheel spin
Is this normal for the true trac?
https://youtu.be/VBKpZSnjzVY
camarosspower is offline   Reply With Quote
Old 04-22-2019, 10:49 PM   #2
bkevind
bkevind's Avatar
Drives: 2013 2SS RS 1LE
the truetrac will behave differently depending on the gear fluid used.
Synthetic in particular (which is why Eaton says not to use it) will reduce the "locking" ability.
468, Mishimoto rad + oil cooler, TSP LTH
MCS 2WNR
CTSV/ZL1 front calipers/rotors + G-Loc
Forgestar CF-5 19x11
bkevind is offline   Reply With Quote
Old 04-23-2019, 08:31 AM   #3
camarosspower
I use just the regular non synthetic diff oil from lucas
Old 04-23-2019, 08:51 AM   #4
bkevind
bkevind's Avatar
Ah ok. I guess you'll have to try a thicker weight (make sure it doesn't have any friction modifier) to increase the bias.
MCS 2WNR
Old 04-23-2019, 09:18 AM   #5
camarosspower
I'll look for thicker weight
Old 04-23-2019, 07:47 PM   #6
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
I don't think your getting the RPMS up high enough. The True-Trac acts as an open differential until power to both wheels is needed.
Once you pull out of the water and get stopped to burnout, get the rpm's up to 5000-5500, keep them there while heating the tires, then ease off the gas while rolling out. All nannies should be turned off as well. I do have a line lock...…... so that may make a difference too, but mine does a 2 wheel burnout every time doing it this way.
You should also be using 2nd gear to burnout with the TH400, so your RPM's may be lower than mine, I still have the stock transmission.
I've ran both versions of Lucas in my True-Trac and had no difference doing burnouts with either. Had my True-Trac in for about a year now.
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 04-23-2019, 10:51 PM   #7
camarosspower
Thanks man. I'm thinking my rpms weren't high enough as well. I'm thinking if the truetrac is bad then the drivers wheel would've never done the burnout
