02-11-2020, 12:59 PM | #29 |
Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
those chps look like they just fall into place based on the video. I pulled the starter and motor mount on the passenger side to get my 1 7/8 Kooks in. Others have apparently done it with out removing anything, but I don't really see how. The fitment on the Kooks is perfect, just a bit of a pain to get the passenger side in. At least it's pretty much a one time thing so not a really big deal.
Baby Blue
02-12-2020, 08:17 AM | #30 | |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
The other obvious advantage is less overall restriction. One advantage of flat-plane V8s (or any engine that has even firing on its exhaust banks) is that it can run very-short-primary headers without as much interference of exhaust pulses from port to port. Nobody is tuning primary lengths for resonant tuning anymore, especially with turbos. Everyone is trying to get turbos and cats as close to the port opening as possible for various reasons. |
02-12-2020, 09:23 AM | #31 | |
Drives: SS 6 speed of course Join Date: Jan 2016
02-12-2020, 09:35 AM | #32 | |
Pray tested 3 different set of headers and Speed Engineering made the most power by a slight amount that he chalked up to being variables. Price, fitment, and quality are the only 3 reasons to consider when shopping.
2016 NFG 1SS A8
02-12-2020, 09:54 AM | #33 |
Drives: Chevy Camaro Join Date: Jul 2019
1300 hundo for headers? These seem nice but wow, thats some high dollar stuff.
02-12-2020, 09:55 AM | #34 |
Due to the odd fire nature of the engine and kind of tight fit, I like the Billy Boat E
Tri-Y Design: https://www.bbexhaust.com/shop/chevy...der-fdom-0365/ But who really knows, the Tri-Y tubes pair ports furthest away from each other, so there is no primary port flow interference with the pulse (fist merge) between the paired ports, the second merge pipes are much larger, so think of this as "extending" the merge point further down via gradule flow expansion. So at the point two ports are flowing at the same time the effective cross section is twice as big. I will note the current thought in Honda B and K engines setup is intefereance merge Tri-Y where the pipes are selected to purposle put two exhaust pulses together. The thought is to keep the energy in the pipe (pressure and heat are energy) and there really is no "reflective" extraction wave on a closed exhaust system, as such waves are generated at the exit point to atmosphere. No way it works (interferance merge), except it does and my current 275 engine HP B engine NA 2.1 liter uses such a header to good effect. https://www.ebay.com/p/19017008225?i...BoCAegQAvD_BwE all inline 4 firing orders are 1-3-4-2, you can see that 3 and 4 are paired. The exhaust pulse of 4 will really start hitting when 3 is tapering off, so you get one really long and strong pulse. Can't work, I know right? Sorry for the threadjack. I'm merely talking theory, not like I'm selling headers. The Complete Street look to have nice bends and a gentle merge collector and that is basically where any potential power gains will come from. What I do really like is the nice straight carry from the exit of the head before the first bend, there is a least one cheap brand that really bends the header tube too soon. Sure you can get more room to fit the tubes in but I like a good 1" or so before I bend the tube. I also like the ball connection as this exhaust is basically one piece and there is some minor movement at this ball which is good.
02-12-2020, 10:22 AM | #35 |
Drives: Turbo 6.2 Join Date: Feb 2019
Andrew said on his channel that they actually picked up a little power vs the kooks on the treel1. I havent saw a video showing the dyno or graph though.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
02-12-2020, 10:34 AM | #36 |
able to use the stock wires is a plus. I have modified stock wires on my 1 and 7/8 Kooks, I made a total of two brackets to loom the wires and modified 3 total stock wires as shown in the picture. Not really all that hard, but how many shops are going to do it? This header looks to work well with stock wire. Once again, not hard (I finally got bent ceramic boots), but shops ain't gonna do it.
02-12-2020, 01:30 PM | #37 | |
Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
So while price, fitment, and quality are in your opinion the only things to consider that doesn't make it a fact or rule. Others may value the power gains from one over the other, however minimal or not. Tsp provides both value, good fitment in the latest batches, and apparently the most power.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
02-12-2020, 01:41 PM | #38 |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
+1
103 Katech TB, KATECH Custom Heads TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 98 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
02-14-2020, 11:01 AM | #39 |
Drives: 2018 Camaro ZL1 A10 Join Date: Nov 2018
02-14-2020, 11:28 AM | #40 | |
2016 NFG 1SS A8
02-15-2020, 07:07 AM | #41 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I'll be very interested in them once some cats come in with them.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
02-18-2020, 08:17 AM | #42 | |
Drives: 2019 Camaro 1SS A10 Join Date: Nov 2015
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6 2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD** 2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD* 2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD* |
Thread Tools | |
