Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Emblempros
Old 02-06-2020, 10:56 AM   #29
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Looks to me like the 90mm is too large of pulley for the 2650...it's being under driven. You will likely have to shift around 7-7200rpm to stay up in good power.
Yeah. Unless it has been changed since the install, that was the CARB-intent kit, which comes with the 90mm pulley. Still - I believe Magnuson said it was right about 14-psi. It sounds like those blowers like closer to 20-or-so, from what I hear and see on the all-truthful interwebs.
'20 ZL1 Black "Fury"
Old 02-06-2020, 09:13 PM   #30
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
The all-truthful interwebs... Yes, the 90mm pulley is for CARB purposes and itís still on. Adding some go fast parts this week and then retuning with Ted. Iím going to wait until I can add fuel before going to a smaller pulley.
Magnuson 2650
SienarSystems is offline   Reply With Quote
Old 02-07-2020, 08:42 AM   #31
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm really eager to see how this round of mods' works out because this was the direction I was planning on going.
Old 02-07-2020, 08:47 AM   #32
JANNETTYRACING
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Be glad to Help you with your project.
Ted.
www.jannettyracing.com
Celebrating 34 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 02-07-2020, 09:03 PM   #33
BlaqWhole
BlaqWhole's Avatar
Drives: 2017 Camaro ZL1 A10
Yes, I was at 640.7 with one modification - the 2650. Stock everything else and a 90mm pulley.
How much would LTs and a Big Gulp help this setup? Or is it an unnecessary expense at this point?
2017 Camaro ZL-1 A10 - Roto-Fab cai - Katech ported TB - MBRP Race catback - VTC!!
2017 Challenger Hellcat M6 - Legmaker CAI - MM ported TB - Sprint Booster!!
2012 BMW X5 50i!!
Saving the world...1 hp at a time!!
Old 02-07-2020, 10:22 PM   #34
SienarSystems
Drives: ZL1 1LE
That’s exactly what’s going on. Kooks, BG, 95mm tb and the JMS fuel pump booster. I’m having it remote tuned by Ted J so I will not get dyno numbers this time. This round was not necessary, and I’m not necessarily looking for a particular hp number, just wanted the sound of the headers and Rotofab. The next round will definitely be for more power, but that means a cam, injectors, low and high side fuel pumps and a flex fuel sensor.
Magnuson 2650
Old 02-08-2020, 02:11 AM   #35
BlaqWhole
BlaqWhole's Avatar
Thatís exactly whatís going on. Kooks, BG, 95mm tb and the JMS fuel pump booster. Iím having it remote tuned by Ted J so I will not get dyno numbers this time. This round was not necessary, and Iím not necessarily looking for a particular hp number, just wanted the sound of the headers and Rotofab. The next round will definitely be for more power, but that means a cam, injectors, low and high side fuel pumps and a flex fuel sensor.
I would think that setup should get you around 700 give or take. I'll be looking to have mine remote tuned as well. But once it is dialed in I'll be going to a shop to get it dynoed to see what the final numbers come out to be. If I get 650-700 then it'll be well worth it. Especially as a first round of mods since I'll be doing more extensive mods down the road.
2012 BMW X5 50i!!
Old 02-08-2020, 05:34 AM   #36
NickeyMatt1LE
Drives: 2017 Camaro SS 1LE
We have done several 2650 swaps on ZL1's in the past month with similar supporting mods to you, plus headers, 85mm/stock lower and 90mm/5% lower pulley combinations. We see about 750 rwhp through a 10 speed auto at 16 psi, 6600 rpm on 93. You'll be 14-15 lbs at 6500 rpm, 16 psi if you take it to 6800 with that pulley combination. It should make an easy 700 rwhp on 93. The 2650 makes WAY less heat than the stock blower. Even at 15 psi you'll be 30-40 degrees cooler than the stock blower at 9-10 psi. You will loose some torque below 3000 rpm because of the way it ramps boost in. By 4500 though it will be up at least a 100 lb/ft over stock. I think it makes these cars way easier to drive on track. I can post up some dyno sheets when I get back to the shop on Monday if you're interested.
NickeyMatt1LE is offline   Reply With Quote
Old 02-08-2020, 06:17 AM   #37
laynlo15
laynlo15's Avatar
Drives: 2016 1ss A8, Npp
Thanks Matt for the input. You guys do a great job at Nickey and build some pretty bad ass rides for sure.
2016 Camaro 6.2, Magnuson 2650 Heartbreaker, RotoFab, Lt4 short block (stock) BTR Cam kit, stock heads, stock trans/converter/diff. Kentshotrodgarage (M/T,Hoosier, Racestar Wheels), RPM RB, DSS, Gforce, Griptec Pulley Best 9.41@146 Best MPH 149 1/4 5.99@119 Best MPH 120 Best 60' 1.35.
Old 02-08-2020, 02:14 PM   #38
BlaqWhole
BlaqWhole's Avatar
Thanks for the info. I have a question if you don't mind my asking. I trust you guys know your stuff. Is it safe at that psi and up to 6800 RPMs? Are you sending them out the shop for DD use at those boost/HP/RPM levels or are you dialing it back a bit. Those numbers look really good to me and if I can get there this way then that might be all I need.
Sorry to hijack the post OP.
2012 BMW X5 50i!!
Old 02-08-2020, 03:21 PM   #39
JANNETTYRACING
I spin mine 6800 on the road coarse every lap i see no issues with doing this.
16 psi boost might be a bit much for 93 octane pump gas, for the road coarse.
For the road coarse I would like to see closer 13-14 ish in limited to 93.
On good fuel I would have no issue running it at 16-17 psi.
Old 02-08-2020, 10:02 PM   #40
NickeyMatt1LE
For road race use I would keep it below 15 psi like Ted said. 6800 rpm is no problem. For street and drag use we do send them out the door at 16 psi though. We had a shop ZL1 we did testing with and had no problems with those power, boost, and rpm levels for street use on 93 octane. That package on a pump/race gas mix we've pushed to 17 psi and 6900-7000 rpm. That will do 830 whp and high 9's on a drag radial in a full weight car. The 2650 really allows you to be little more aggressive with theses lt4's with proper tuning. So dialed back to around 700 whp will be a reliable road course setup.
Old 02-09-2020, 07:05 AM   #41
laynlo15
laynlo15's Avatar
What they said.
Old 02-09-2020, 08:18 AM   #42
L78toLT1
L78toLT1's Avatar
Are you still running the stock blower on your ZLE, Ted?
Baby Blue
2016 Hyper Blue 2SS/6m/MRC/NPP/Silver Rally stripes/ZL1 wheels/6 piston Brembo's/GForce DS and axles/SEMA Grill/Rotofab dry/Pray ported TB/Magnuson Heartbeat with 85mm pulley/Full LT4 fuel system/JMS boost-a-pump/Skidmark Garage E85 Sensor/JRE Smooth Idle Cam/GPI piston/rod kit /APR main, head, balancer bolts/Kooks 1 7/8 headers with high flow cats/JRE remote tuned
L78toLT1 is online now   Reply With Quote
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
